Launch iTerm by Command+Control+T
I added a shortcut of Command+Control+T to launch iTerm.app. However, pressing the shortcut launches dialog to select either "Launch iTerm.app" or "Launch Terminal.app".
I want the shortcut to launch iTerm directly instead of showing the dialog. Is there any way to do that?
Thank you,
Hiroyuki
you probably have added the shortcut twice, one for terminal one for iterm. In that case BTT will show the dialog.
I did not realize there is one for terminal... Removing it solved the problem. Thank you!
