I set up some keyboard shortcuts (Fn + Up/Down for Scr
een brightness and Option + Up/Down for volume) and since the latest update they don't work anymore. I tried downloading the previous version but it still doesn't work.
Can anyone see what I do wrong?
Thanks in advance
Maybe check if Secure Input is activated (BTT shows that on the very top when clicking the BTT menubar icon)
If so, you may need to lock your screen and unlock it again using your password - sometimes macOS forgets to disable Secure Input. FN based shortcuts don't work while Secure Input is active.
