The key sequence is as follows
It can be triggered when I press command+space, and then P, A. However, it can also be triggered when I press shift+space, and then P, A. This is the problem. I also had a key sequence where the only difference is that the left command is replaced by right command, and it works fine after the left command version is disabled, that is, "shift+space, P, A" won't trigger the key sequence. Oddly, I just found another pair of key sequences (command+space, P, B / right_command+space, P, B) is an opposite situation. When I disable the right command version and remain the left command version, it works fine, that is, "shift+space, P, B" won't trigger any BTT key sequences.
macbook keyboard
- Type of Mac: MacBook Pro 2017
- macOS version: Mojave
- BetterTouchTool version: 2.645
