key sequence not working
the simple modifier key sequence, all on left side does not work.
Press ⌃ → press and release shift twice → release ⌃
thank you for your help
Did you adjust the time because the sequence is longer?
No, I had not and it fixes the problem. thanks very much @Frank1 !
