After updating to macOS Tahoe 26.0.1 (25A362) on Apple M1 Pro, I noticed an issue with a key sequence I previously mapped. I had set the sequence cmd + shift to trigger ctrl + space, which I use for changing the input language.
Since the update, pressing cmd + shift no longer switches the language immediately. Instead, the language only changes after I press another non-alphanumeric key. I have not tested all possible keys, but so far, keys like caps lock, shift, ctrl, cmd, and option work to trigger the change, as well as probably others.
Steps to reproduce:
On macOS Tahoe 26.0.1 (25A362) on M1 Pro, map
cmd + shiftto triggerctrl + space(input language switch). -
Press
cmd + shift. -
Notice that the language does not change until an additional non-alphanumeric key is pressed.
Affected input device:
Ergo K860 Bluetooth connected
Type of Mac: Apple M1 Pro
macOS version: 26.0.1 (25A362) Tahoe
BetterTouchTool version: (You are currently running version 5.739.)
exported_triggers.bttpreset (2.1 KB)
