'keep group open while switching apps' parameter doesn't work on apps with behaviours that are set to show macOS bar, hide CS when BTT bar open'. The bar just closes to the macOS touch bar.
mh, that is expected behavior. The app settings always override any other setting. I don’t think this is a bug. (also would be very hard to solve without introducing yet another level of complexity :-))
Possibly you could have a activation group that overrides the setting when a specific group is open, but it is currently kind of random which settings are chosen when multiple apps/activatuon groups are active. Maybe I can add a priority parameter to the CAGs
