Issues with some triggers and actions after MacOS 27 update - Show notification, clear notification, and show control center
Title: Notification and Control Center actions no longer work on macOS 27
After updating to macOS 27, the BetterTouchTool actions "Show Notification," "Clear Notification," and "Show Control Center" no longer work. These are the only triggers I've noticed that stopped working; there might be others I haven't noticed yet.
The triggers still activate, but these actions produce no visible result:
  • Show Notification does not display a notification.
  • Clear Notification does not clear notifications.
  • Show Control Center does not open Control Center.
Steps to reproduce
  1. Update the Mac to macOS 27.
  2. Assign any trigger to one of the affected actions.
  3. Trigger the action.
Expected behavior
Notification center should be shown and cleared, and Control Center should opened/closed.
Actual behavior
Nothing happens for all three actions.
Device information
  • Type of Mac: Mac Mini M4 Pro
  • macOS version: macOS 27
  • BetterTouchTool version: 6.820
Additional information
The issue began immediately after updating to macOS 27.
Bump
Also, upon further investigation, I found that the shortcut for control center, works for closing the control center, but not opening it. So opening it manually (with the mouse cursor), and closing with keyboard shortcut, seem to work.
"Show Notification" and "Show Control Center" are still working for me on macOS 27 (BTT 6.848) but the "Close All Notification Alerts" no longer dismisses all notifications
"Close All Notifications" should now work on Golden Gate with v6.855 (uploading)
I'm also having issues with triggers and actions not working after the update. I haven't changed any settings; the text replacement keyboard shortcuts via Mac settings work, but my shortcuts via BTT do not.
sounds like a permission issue, quit BTT, then delete (not uncheck) it from System Settings -> Privacy & Security and add it back manually. Unfortunately the macOS permission system is still buggy after all these years.
