The Capture Screenshot (Configurable) action no longer works. As you can see on the screenshot below, the action appears in the Trigger Predifined action field, but it does not in the Assigned Action tab.
I restarded the Mac, reinstalled version 2.727 in hope that it could be a bug that affects version 2.728, but the problem has not gone away.
I also tried other shortcuts and checked every other application (e.g. KeyBoard Maestro, Alfred, etc.) which could be conflicted with BTT for that particular action but found nothing.
Affected input device : Keyboard, Magic Mouse
Screenshot
- Type of Mac: iMac (Retina 5K, 27-inch, Late 2015)
- macOS version: 10.12.6
- BetterTouchTool version: 2.728
Thanks in advance for your help.
P.-S. It’s also worth mentioning that the problem started when I tried changing dates format and the file name in the action configuration. After that, I tried again several times without changing anything.
