6.545 adds pinning options for the list
Also it's now possible to select multiple items in BTT and add them to the launcher simultaneously.
Oh, that was quick ![]()
But unfortunately, nothing is triggered when the list is pinned... at least not here.
what kind of actions are you trying? It seems to trigger fine here but I only tested some things
Any. Insert time or date, transform text ...
I'm on Ventura.
ah so all generating keyboard output? I'll check, maybe I need to adjust the timing for these a bit to work across systems
Yeah, now that you mention it... other triggers seem to work.
6.547 should resolve this (uploading), it now uses the same triggering style as a pinned clipboard manager
Yeah, with 6.547 everything seems to be fine, thanks, Andreas ![]()
One more thing: Clicking the pin icon works fine. But a shortcut to pin/unpin would be even better.
I could probably achieve that with a condition too... if window (name) is visible, then...
But it would be better if it were built-in.
Maybe it's a bug... or maybe not... just to be sure.
Only one list can be open at a time; not multiple at once. Right?
And: If two different lists, opened with different shortcuts, have the same setting here...
...then changing one setting (eg. moving the list) affects both lists. That's not ideal.
Currently not, but I think I can add support for this while pinned.
That would be very useful. One use case would be to have a narrow pinned list at the edge of the screen, for example, to transform text.
And still have the option to open another list to trigger something else.
And, if I am allowed
... these two actions
use the same type of window as the lists. Right? If you could pin them small at the edge of the screen, you’d have a small but always-visible window with all running apps/windows.
In a way, this is already possible. The window stays open for a while and then closes. I'm not entirely sure what criteria determine this ![]()
I just wanted to gently ask if that's still on your to-do list and, if so, when you plan to implement it.
yes, next week!
6.621 adds support for multiple pinned searchable lists. I have only tested in on macOS 26 so far.
