I wanted to add it to my locking gesture so that when I walk away it locks my computer and also makes sure it doesn't distract people if I get a call but unfortunately it currently also unmute's my laptop so that it plays sound if I originally had it on mute. Any help would be really appreciated.
Is there a solution to this by now? Can I check the mute status as condition for trigger?
You can initiate an Applescript with a trigger. Something like this, for example.
set volumeInfo to (do shell script "osascript -e 'get volume settings'")
if volumeInfo contains "output muted:true" then
display dialog "The output is currently muted."
else
display dialog "The output is not muted."
end if
FYI: You don't need to run a shell script inside of the Apple Script:
set volumeInfo to output muted of (get volume settings)
if volumeInfo is true then
else
end if
If you want to use the muted state as a condition, you need to create a dynamic java script variable in the "Automations, Named & Other Triggers" section. This can then be used in the advanced trigger conditions.
let result = await runAppleScript('output muted of (get volume settings)')
if(result === "true") {
returnVariableValue("muted")
} else {
returnVariableValue("not muted")
