Is it possible to use wifi changes as a trigger?
Triggers for Wi-Fi names do not support multiple name or regular expression matching. Is it possible to use Wi-Fi changes as a trigger?
I guess maybe you can use "Advanced Conditions" with a suitable operator, e.g. "ends with":
I'd like to use Wi-Fi changes as a trigger, but "ends with" can't listen for Wi-Fi changes and then trigger some action. And "if condition" can't be used as a trigger.
The trigger will be one of:
and then you go to the "Advanced Conditions" of that trigger and use the "ends with" (or other)
I've used this trigger, but one problem is that it only supports one name, and it doesn't support regular expressions, so if I want to work with several wifi names, I need to create several triggers.If there were an "on wifi change" trigger here, I could handle all wifi change situations in the "if condition".
good point, I'll just add regex support for the next version, this will help with various other triggers as well
