Sorry, I didn't test it carefully enough. All actions work with other apps. But not in the Finder (not even the one below). I wouldn't have thought of that.
Why only in the Finder? It could have something to do with my Mac.
Weird indeed. There is the visible window viewer in the Advanced Conditions configuration, does that one show the Finder Downloads window?
Yes, the window is displayed: “Finder - Downloads - 0”
However, the actions do not work with any Finder window ... Downloads, Documents ... I can live with that.
But I have one big request: Could you also incorporate the pin/unpin function into the action below?
So, trigger displays the window and pins it. Trigger again unpins the window and hides it.
Of course, it would be even better if pinned windows could simply be minimized. The idea would be to show/minimize a pinned window.
I don't think that's illogical: if the window is visible, it's pinned. If it's minimized, it's no longer pinned.
I believe that most people don't use the “minimize” function (cmd + m) because Apple hasn't implemented it very well. How do you find these windows and make them visible again?
Since BTT can display minimized windows, it's very easy.
This is perfect for windows that you don't need every few minutes. For the other windows, the aforementioned action works with a shortcut. And if you could also pin these windows, the BTT miracle would be perfect.
incredible, first time I ask something and there is already the feature added. As a new customer, I am very pleased ![]()
