Insert / type / past text not working - types nothing but correctly executes rest of the shortcut.
Keyboard shortcuts
MacBook Pro 2021
v3.746 (1888)
Keyboard shortcuts
MacBook Pro 2021
v3.746 (1888)
Could you post a screenshot of how your configuration of the action looks like?
And could you check whether the issue is still present in v3.747? If so, it would be great if you could go to "Help => Export Diagnostic Debug Information" and send the result to andreas@folivora.ai
Problem now solved itself Andreas. Thanks.
