Interesting.. So do you have multiple copies of the exec for each app?
Also how did you compile it? and what's the code behind it too if you don't mind..?
I'm just wondering if there is a way to embed it entirely into a BTT preset so that users don't need to hassle with putting it in the right folder, etc.
I doā¦ Didn't find a way to do another way. I thought of using update_touch_bar_widget (from Apps) but as I want a button for each app it doesn't seem doable : using update_touch_bar_widget I can set the correct icon but I will only be able to display one app at a time. And as I'm only interested in 3 apps, I think performances are not affected.
Just something that comes to my mind, we may be able to run the script (without parameter) as an Other action, and store it's result using set_string_variable and then read this for every button, and show the button if needed. Basically, if variable contains appName return show else return hide. May be better ?
I don't know about including an utility directly into a preset, but I'm pretty sure you do
EDIT regarding my previous suggestion :
Sorry, I thought we could set up an Other action that runs script every X seconds but it's not the case. So I've added a TouchBar button to run this script. Here is the code :
Button to update badged apps :
set_string_variable "notificationBadgeApps" to (do shell script "/Applications/Utils/dock-notification-count")
return ""
end tell
For each app button :
set notificationBadgeApps to get_string_variable "notificationBadgeApps"
end tell
if (notificationBadgeApps contains "Mail") then
return true
else
return ""
end if
Seems good. I havenāt seen any files but I see what youāre getting at here. Iāll need some time to check this out first then iāll tell you what I think!
I see you have a helper widget (well thats what I call them) that sets the variable and then every other widget reads it. The code is much smaller than what me and @GoldenChaos use too (compare to his first post) so iām guessing itās more efficient? not sure here.
One thing though, can we return the number of notifications and any handoff badges? as it is what the current ones do.
Iām thinking we could either use text handling for each widget to get the corresponding number or we could have the helper widget write to a plist file which the others read. Iām not exactly sure which is more efficient, but I think the plist would be more efficient as its less of a process to get the corresponding number? not sure.
Also itāll be great if you could check if handoff works. Currently if handoff becomes available, itāll display something like āiPhoneā which you can tap to use handoff.
Is there a way to load this script into BTT so a user doesn't have to manually compile or download it, or have the functionality integrated into BTT somehow? Can we know if this is actually more energy efficient than the AppleScript method?
cc'ing @Andreas_Hegenberg since this seems promising and I want him to destroy my hopes and dreams
@GoldenChaos sure : the app is doing the same as the compiled Apple Script (using the accessibility API), so unless Apple Script is buggy it shouldn't be much faster. However as it's starting a new process which is quitting immediately again it will not show a big CPU impact anywhere.
However I'm happy to add a function that executes this code directly in BTT and can be called using the BTT scripting interface, then you can do some more experiments
I think it could be more efficient since the script is ran only once every N seconds, instead of having to do it for each button (like initial Apple Script).
I've made some performances experiments with top -pid $( /Applications/Utils/dock-notification-count > /dev/null & echo $! ) but can't really compare it to previous implementation :
By the way, @GoldenChaos, when you said "they notoriously hog energy", how were you able to tell it ? By comparing BTT script usage from Activity Monitor with and without script enabled ?
When dock badges were first implemented, they were all enabled by default. Users (including myself) suddenly noticed that our systems were getting one hour of battery life and constantly running at ~20-40% CPU at ridiculous temperatures. @Harrumph made a great post with CPU stats to verify: GoldenChaos-BTT Support and Feedback Thread
The underlying code for dock badges hasn't changed since then. We were unable to find a true solution, all we could do is turn on as few dock badges as possible by default, which led to the current default setup of apple-only apps being enabled.
The holy grail, naturally, is being able to support enabling all dock badges at once by default, eliminating the need for user configuration.
Oh okay I see, indeed it was huuuuge CPU and impact on battery !
So after two days of using it, I can confirm that I don't see any negative impact with my implementation. Still have ~8hours battery life, and CPU absolutely not affected (at least < 10% when doing nothing CPU-consuming).
Even if I add a TouchBar button for every app in my Dock, I'm pretty sure it won't affect performances as the only script running in these buttons is fetching the value from the BTT variable.
I think it'll be less too, as only one script looks through the whole dock once and spits out a list which we can store somewhere.
Currently every badge digs into there every second, each making a new (request? i don't have professional knowledge here), added the very low efficiency of applescript too.
@AnthoPak, do you have the seperate exec method setup now or did you figure out how to use the one that spits out a list?
@GoldenChaos I've made the try creating a button for each app in my Dock, and as expected, I don't see any difference. Every new button only executes following script, which can't use too much CPU as it only fetch a variable value :
end tell
return true
else
return ""
end if
@yuuiko I'm currently using the implementation I've posted in #22. This is only calling the helper once, and then every button fetch the last response from the helper. So no need to re-run the helper for each button, therefore no performance issues.
The only thing I regret is not having the ability to create buttons on the fly based on helper response, which could be even better. In current implem, I have to create a button for every Dock app, and each one has to update every 10 seconds to see if app name is contained in saved variable.
BUT ! Something just came to my mind (againā¦), I could use the helper widget, and without saving the result in a var, use update_touch_bar_widget from BTT API to change buttons text, and therefore changing their visibility. This would avoid having each button updates every 10 seconds. I may try this when having some time
Okay, I've finally found some time and implemented my above suggestion
Works really well ! Only one script for an infinite number of apps
I even tried setting the refreshing time to 0.1s and don't see any performance issue, no difference in CPU usage But of course 0.1 is useless, I'll stick with ~2s I think.
(EDIT : in fact i've just noticed that with 0.1s I got BetterTouchToolAppleScriptRunner going to ~5% CPU, whereas it almost always < 1% with 2s. But this performance change may mostly be related to widget update)
So basically, here is the process :
Create a widget for each app we want (in fact a button could be sufficient, but update_touch_bar_widget is, as it name suggests, made for widgets and not for classic buttons). I've set the refresh time of these widgets to 10000 (as I don't want them to refresh themselves)
Copy the UDID for every button, and add it to following helper widget script
Create the AppleScript helper widget that will update each button when needed, and this script :
UpdateDockBadgesButtons.scpt :
set udidRecords to {Mail:"EE7C0AF6-8406-4278-879F-593CFBCD1000", Messages:"0ECB327C-0CC9-4C12-B300-1BC7210F74B9", Franz:"7E02811B-73E3-458E-967A-9DFD11D101DB"} --All UDIDs from BTT widgets for apps that you are interested in notifications badges
set notificationBadgeApps to (do shell script "/Applications/Utils/dock-notification-count")
-- Can't make a loop here since I can't find a way to fetch records from udidRecords with variableā¦
checkAndUpdateCurrentBadgeStatusForApp("Mail", notificationBadgeApps, (get Mail of udidRecords))
checkAndUpdateCurrentBadgeStatusForApp("Messages", notificationBadgeApps, (get Messages of udidRecords))
checkAndUpdateCurrentBadgeStatusForApp("Franz", notificationBadgeApps, (get Franz of udidRecords))
return "" --hidden helper widget
on checkAndUpdateCurrentBadgeStatusForApp(appName, notificationBadgeApps, udid)
if notificationBadgeApps contains appName then
updateButtonWithUDID(udid, "show") --here we can try fetching badges count from notificationBadgeApps if we are interested in getting badge count, and replace true with count
else
updateButtonWithUDID(udid, "") --hide button
end if
end checkAndUpdateCurrentBadgeStatusForApp
on updateButtonWithUDID(udidToUpdate, newText)
update_touch_bar_widget udidToUpdate text newText
end tell
end updateButtonWithUDID
Still, creating buttons on the fly will be even better so we won't have to deal with UDIDs, but I've also looked into add_new_trigger and I don't think it could create a button. This could definitely be a great new feature.
Personally I don't mind making a bunch of badges for every app, though being able to create and remove "virtual" buttons on-the-fly is something I've wanted for a while and would make the reminders/calendar/browser tabs groups behave a lot nicer. I might make a separate thread to request this feature, I know it's come up in the past and add_new_trigger isn't a good option for this because it creates permanent buttons.
