Hi.
Despite BBT's palm and thumb detection, unwanted trackpad events are still a pain for me. Would it make send to have a setting that the trackpad will be ignored if a keyboard press happened in the past 100ms? Perhaps 200ms or even 50ms might be effective.
Thanks,
Alan.
Unfortunately BTT can only influence it's own trackpad gestures. This can be enabled in the advanced trackpad preferences:
You could also check "Reenable only after touching the center area of the trackpad", then BTT gestures will be ignored until that happens.
Thanks for the response Andreas. It's a pity it cannot be extended to all Trackpad gestures.
