IF - ENDIF trouble
Hallo,
I have some trouble with IF / ENDIF in my Named triggers.
Not sure yet why, but sometimes nothing appears to run after the END-IF ?
For debugging I have two HUDs and the second HUD does not show sometimes (and nothing after runs anymore).
Even if the IF fails it should show the second HUD always, but it does not. It shows sometimes... any idea what is going on?
Thx,
Christian
BTT version 4.516
I'm trying to reproduce this. Is it depending on whether the if is true or false, can you see any pattern?
I'm trying this, but it seems to always trigger all huds
No, can not see a pattern yet, my IF condition is always true, (the variable is set once to yes).
I keep an eye on it and report back any findings..
