Are you triggering the keyboard maestro macro from a BTT trigger or directly via a keyboard shortcut? (I'd recommend to trigger it via BTT, then my solution posted above should work fine). Or maybe you can replicate your Macro within BTT?
@Andreas_Hegenberg great! The arrow key problems seems to be fixed, but the stuck modifier keys bug is still going strong This time, somehow, I managed to get it permanently stuck and had to turn the keyboard off/on in order to undo this condition (I got it on video and can send it to you if you want). Can it be related to external/bluetooth keyboards somehow?
Just verified that it is happening with the keyboard on the cable.
Also, somehow, I've managed to lock BTT in a state where, if it is open, the hyper key is perpetually stuck, even if I close and reopen BTT. I was thinking about reinstalling BTT and see if something improves, just wanted to check in with you first, @Andreas_Hegenberg in case you'd like me to run any tests/diagnostic in this bugged state.
OK, I'll try to downgrade and see. Right now (after reinstalling and updating to the latest alpha) the hyper keys combination is not stuck anymore, but all my older shortcuts are still working if I invoke them using CTRL+ALT+SHIFT+CMD, even though BTT is not showing any keyboard shortcuts.
OMG, sorry about these latest issues. I've updated Alfred in the meantime and it apparently reenabled a couple of old workflows I used to have. That's why the shortcuts were working even when nothing was set up in BTT.
I'll keep testing to see if the stuck keys are still a problem. Thanks @Andreas_Hegenberg!
I have done more testing and various stress tests but couldn't reproduce a stuck key issue in v3.549 (alpha). If this is still happening for you with that version, it would be great if you'd go to Help => Export Diagnostic Debug Information and send the result to andreas@folivora.ai
