Hi there, I am trying the app for presentations, and it's annoying when presenting the action hud overlay. It's supposed to be deactivated but it still appears on top of the app. With that happening, the app is useless. Any idea what I am doing wrong or if it's a bug?
Thanks
Hey,
for which trigger type? Siri Remote?
There is currently an issue with the Siri Remote where the new UI doesn't show the "disable hud checkbox" correctly. This will be fixed soon.
For now you can open the old UI by clicking the menubar icon, then choose "Old Configuration UI"
