How to temporarily deactivate a CAG?
What is the easiest way to temporarily deactivate a CAG? Perhaps a predefined action activate/deactivate CAG (name) would be helpful?
Currently the only ways to temporarily disable CAGs are either:
  • put them in a separate preset
  • use the predefined action "Set Value For Variable" to set a value for the variables customVariable1 - customVariable6. Then in the CAG have a condition that disables it depending on the contents of customVariable1
An action to temporarily disable a CAG should be easy to add though.
