How do I sort / organize / arrange triggers ? On my layout, if I click the Trigger Name bar at the top, the triggers do not rearrange alphabetically or according to gesture.
thank you
just drag & drop to move them around
that works when you click into a floating menu, where you build the buttons and actions, but not the list of floating menus themselves.
Could you post a screen recording? Reordering seems to work fine here:
