I see there is a new drop down selector style for advanced condition but how can i search it quickly- earlier i used to just type first few letter of condition and it selector falls to it- but now its not happening @Andreas_Hegenberg
Also does the new update increase trigger area for like upper right corner- as I am having issue as the area has significantly increased- v6.438? @Andreas_Hegenberg
This is something which I've also noticed, but I guess it was replaced by the "Filter Variables" on the right.
yes, you can use the filter/ search bar at the top of the right sidebar, then click the little arrow icon to add the variable
The recognition area didn’t change (there is an advanced option in the trackpad settings to make it larger, maybe you enabled that?). You can open the live view, it can visualize the currently set corner recognition areas
I really liked previous approach where in text field i can just type out and hit return to select- now it the right sidebar search - shows only , can’t navigate or select via keyboard and require to switch to trackpad
Is there anyway to increase the top red zone?
where in advanced setting?
do I need to set only use corner and middle
The keyboard navigable sidebar is included in 6.440, the context menu shows now a "Search / Filter" item at the top that will auto-focus the sidebar search field.
Thank you for prompt solution!!
