I've already made a post about this but it got no responses so I've done some digging. using the live view feature I found out that the problem is just that tip taps can't be spammed. I think it's trying to remove accidental clicks, but I just wanted to know if there was a way to remove this built-in delay between when taps are allowed. The weird part is when I was messing around with it I got a couple of instances where it would do two tip taps very quickly, So this delay doesn't seem to be a set thing.
