I am pretty new to macOS and pretty new to BTT. I bought a license cause I use PF that wouldn't support touchbar yet.
I want BTT only present when I open Pathfinder, when I start using pages I want the standard Touch Bar back. This is probably just a setting I haven't found yet.
think I found some solution. I have set up screenshot button and time widget as global, that's why it stays active all the time. If I set up pages to use default touchbar I get the effect I am looking for, but that's a lot of work - get all apps there setup. Any way of having BTT do that by its own?
