Hi @Andreas_Hegenberg - quick question - how to find the proper path for BTTShortcutAppUnderCursor
? Sending a json that lacks this field does not trigger actionType=128
unfortunately. So my question is: do you know a way how can I get this kind of string com.apple.dt.Xcode
from application path? (\/Applications\/Xcode.app
in this case)
If there's a file somewhere in the system / api then I'll be able todig around and get this value, but a hint would be helpful (I'm mostly doing webdevelopment and I don't know the OSX architecture nor convetions)
"BTTTriggerType" : -1,
"BTTPredefinedActionType" : 128,
"BTTPredefinedActionName" : "Send Shortcut to Specific App",
"BTTShortcutApp" : "\/Applications\/Xcode.app",
"BTTShortcutAppUnderCursor" : "com.apple.dt.Xcode",
"BTTShortcutToSend" : "1",
"BTTEnabled2" : 1,
"BTTUUID" : "CFF20365-3E08-49D9-A789-C1888BFFED75",
"BTTTriggerOnDown" : 1,
"BTTEnabled" : 1,
"BTTShortcutKeyCode" : -1,
"BTTShortcutModifierKeys" : -1,
"BTTOrder" : 103
Ultimately, I want to know what BTTShortcutAppUnderCursor
for given BTTShortcutApp
(this will be a dynamic variable, in the helper lib that I'm building around BTT).
