How to disable spread-two-finger-gesture while rotate
I like to rotate two fingers to change volume. While doing that some times an other apple/btt-gesture is triggered: Two fingers spread or the opposit.
Is it possible to disable this gesture while rotating? Also a second or so after this gesture, because while rotating there might be a break.
Thanks,
Joseph
