Hey all,
I'm trying to call BTT actions from a Stream Deck. Stream Deck buttons can open Websites and run Applescript.
I though I could call UUIDs through a URL (and consulted this documentation to try to make it work) but it doesn't serve my purpose because BTT has to be focused apparently.
Can anyone lend a hand? Thank you.
you can also use the "execute_assigned_actions_for_trigger" apple script function
http://docs.folivora.ai/docs/1102_apple_script.html
(I'm in the finishing phase of the official stream deck integratio, but until then Apple Script is probably best)
Awesome! Thanks for the speedy reply.
Also, great to learn you are in fact still working on the Stream Deck integration. I've been thinking about it often and wondering when/if it will come out, ever since your tweet!
