i install AltTab, with the hotkey “Option + Tab” to switch between the last and the second-to-last window, when i tap “Tab” multiple times while press option, it will change to next window. when i release all key it will jump to the window i stop.
i want to acheive the result that when swipe left and right, and i can change to the last or next window(app) directly and repeatly. that means if i swipe multiples times, it will jump to the second-last, third last app.
I tried using if conditions, AppleScript, modifier keys, etc., but none of them worked. i really need some professional to help, it means a lot to me, i want to use this app but it turns hard. thanks a lot!
this is a pain to realize - but I’ve managed to realize it with a dirty hack (using the CLI command of AltTab and “Cycle through multiple actions” in BTT).
Not beautiful, but it works. See attached bttpreset.
I've already imported it, but it doesn't seem to do anything and I can't trigger anything. Could it be because I set the shortcut to Ctrl+Tab? Can I change it to the one you suggested?
to be honest I would highly suggest you to give the BTT Window Switcher a try and solve your UseCase without the App AltTab - it’s just too complex to get this to work.
You can find a easy example attached:
5F Swipe Left opens the Window Switcher with the next window focused
5F Swipe Right moves up in the list
5F Tap focuses the selected window
I hope from here you can iterate forward on your own.
