I use a "Named & Other Triggers" trigger called "Move Mouse To xxx Corner". When I use the menu bar action "Disable BTT for ... > Disable BetterTouchTool For All Apps", the corners still activate.
Device information: 2016 MBP (no touchbar) and 2020 Mac Mini with Apple Silicon. Both MacOS 11.3.1. BTT 3.552
