It doesn't matter when you don't use BTT, but when you use BTT and use Mission Control set to Hot Conner, the Menu bar is blocked by some black object. The Menu bar blocked in this way does not recover unless BTT is terminated with cmd+Q.
Menu bar problem due to mouse pointer movement.
- Type of Mac: MacBook Air m1 (2020)
- macOS version: Monterey (12.2.1)
- BetterTouchTool version: 3.742
I am hiding the Menu bar and using it. (cover it while using it)
