I’d like to be able to hold a modifier and draw my gesture. I’ve worked out how to push the modifier key and THEN draw after releasing the key, but I’d love it if there were a way to draw ONLY while the modifier key is held down. Is this possible?
yes, record one key sequence for your modifier key "down" press, and one for the release - like this:
Exactly what I needed. Thanks for the help!
Hi is there a way to activate drawing while holding the shift key and stop once released?
-i have btt lifetime license and found it difficult to use drawing mode on macbook trackpad
-recently tested betterandbetter china version.
-an inferior ver of btt
-however they have very good drawing shortcuts
-the hold down shift key to draw on trackpad function is v useful
-release shift key to stop drawing
-since my left hand usually stays on the keyboard
-its easier to activate and doesnt conflict with other shortcuts
Did you look at the video in the post above you? There it is shown how to achieve this.
Thank you. managed to make it work.
May i also suggest the possibility of adding a new 3 finger gesture?
-ive experimented with 3 finger tip tap (left/right) and noticed it causes slight nerve irritation in my fingers
-a more comfortable variation of the 3 finger tip tap (2 tap left) for me is keeping the fourth finger on trackpad and tapping both index and middle finger together at once
-it feels more intuitive for me
Is it possible to add this new gesture to trackpad?
Thank you
Update: I managed to create it by adding own gestures. while setting touch duration to 0.01s
