@Andreas_Hegenberg Do you have any idea why arrow down does not highlight the first menu item?
I try something very simple, but it does not work.
open a custom menu, short delay, then press arrow down.
The result should be that the first entry of the menu is highlighted. Manually it works fine, but not like this.
