Just wanted to let you know I've been seeing way higher energy use with alpha 2.648, enough to lead me to downgrade back to 2.646. Usually BTT uses about an energy rating of 1 on my mac, but with this alpha it rose to about 8.5, the highest on my computer, and I found the weather widget would sometimes freeze, and seemed to cause the fans to spin up. I have not changed any configurations or scripts between 2.646 and 2.648. Not sure if it's an isolated issue, but wanted to make you aware!
MacBook Pro
- Type of Mac: MacBook Pro 15" 2017
- macOS version: 10.14.0
- BetterTouchTool version: 2.648
