Help with Touch Bar
Hi there guys, (bit of a beginner so bare with me haha)
I've been having issues with BTT after not using it for a few months, when going back to it, I discovered the app literally wasn't working at all.
Long story short, I checked the application was up to date and it was. I then decided to delete the file a re download it along with the presets I use. This seemed to kind of work, but the Touch Bar isn't responsive and is stuck on the 'tap to show customised better touch tool Touch Bar'. I've tried to use the keyboard shortcuts to unhide the touchbar etc but nothing is working.
Thanks in advance :slight_smile:
