As soon as I tried to add my first action in the Notch Bar feature, BTT started quitting and closing. Each time it re-opens the menu bar disappears and then reappears when it BTT closes. I can't stop it. BTT is automatically opening and closing on its own, and it won't stop.
My setup: iMac, macOS 12.01.
Another question: I have a clone back up my system. Is there a BTT related file that I can restore from the clone backup before I created the Notch Bar acton?
Please advise.
- Type of Mac: iMac 27"
- macOS version: 12.01
- BetterTouchTool version: (please post the exact version - not just "the latest one") BTT won't stay open long enough, so I can't see the version. It should be the latest.
