I came to realise this evening that the web server is no longer hosting my little HTML cheat sheets I use for keyboard shortcuts. I went and recovered some backup presets to take me back to when it was working, but the problem persists, and I haven't broken my settings.
Since updating to the alpha version the other day, this might be the problem.
It looks like I'll have to roll back to an earlier stable version. Can someone advise me on how to do this? I can't find a download of the stable version 5.295. I've attached the debug files if this helps.
Thanks in advance.
you mean the integrated webserver for files located in ~/Library/Application Support/BetterTouchTool/BTTWebServer ?
Is it still enabled here?
I had a look at your debug info, the cheaters.menu floating menu's z-index is set to "same as desktop icons" is that intended? (that makes it show up behind all other windows on the desktop)
It’s definitely intentional because when I have the menu open, it takes about 10% of the screen and sits on the desktop. Since I have a wide monitor, I can use something like Final Cut Pro in a windowed mode and when I hover over the menu it quickly comes forward. When I de-hover, it quickly slips out of the way. I usually open and close the menu with a keyboard shortcut, but sometimes I like to have it on the screen while I’m editing or using another app (it keyboard shortcut lists for over 20 apps and is constantly updated)
I tried to create a version that opens only on my laptop and is triggered by using Final Cut Pro. It resizes the menu to be a dot and sits in the corner above all apps and resizes to a normal size on hover. I was using the trigger for Final Cut Pro to open as a conditional activation group, and the menu changes its hover attribute and location on the screen. However, I broke the menu and had to go back and rebuild half of it.
How can I make this happen smoothly? Especially the trigger to return the menu to its original state, because thats how I messed it up
Thank you for your help.
Yes that's what I'm talking about. I checked and all is activated.
But, an hour later it started to work again. My bad,.
