Have specific actions for Mac Laptop Trackpad and external Magic Trackpad?
Hi there,
I'm just wondering if there is a way to toggle actions to only work with my external Magic Trackpad and not with the in build Trackpad?
For example I am tapping the corners of the inbuilt one when I type and I would like to have them as actions on my Magic Trackpad.
Been trying to search for the correct terms but failing to find if this is possible..
Thanks so much :slight_smile:
polyphant
See this screenshot:
Ah ha, I didn't see the SAVE button at the top which comes on when you select this.
Thanks so much for the reply.
