atm to create an accurate setting for something like rotate block time
or tiptap sensitivity
its really hard using the mouse or trackpad, but when having an input field to directly enter the value, it would be much helpful & easier for new comers.
PS:
if possible, can we also lower the decimal precision, so instead of the current 16 digit, i believe the first 3 or 4 digits are more than enough, plus it will avoid the ui leakage between different parts because of the long numbers.
