Has BetterTouchTool considered allowing imports and exported of individual actions / triggers?
Right now the only way to do it is by adding them to presets. What if You could right click on a trigger to "Export action", and import individual ones under a menu bar items? I guess it could be under "presets", "Import action."
select them, then right click -> export selected triggers to file
