h@llo.ai fallback model OpenCode
Hi Andreas,
The fallback model in the main BTT window is "Open AI", but in the wizard OpenCode CLI is selected.
OpenCode CLI is not even in the dropdown:
I've tested and removed the primary model, asked the AI and it said that it is opencode/big-pickle (fallback model), so it seems that it worked, no matter that the Fallback API Type is showing "Open AI Completion or Compatible".
Not sure if this image will help, but still:
BTW, is it supposed to be "Open AI" instead of "OpenAI" ?
I'll add support for CLI fallback models later today!
Andreas, the fallback model drop-down still shows only the above 3. Not a big deal, just FYI.
Btw, what is the difference between "Optional Model" and "Fallback model".
