I've been experiencing an annoying but for the last few updates where pressing the Command button on the mac will reopen my last opened touch bar group. This happens if I select something within the group and the group automatically closes, without me manually closing it. When I then press Command the group reopens until I manually close it.
Touch Bar
- Type of Mac: MacBook Pro 15" 2017
- macOS version: 10.13.6
- BetterTouchTool version: 2.605
