I'm a new user to BTT. I set up some settings on my own for the Touch bar among one a group. I set a group separately for the Finder and Chrome. The issue is when I click on the group, I cannot go back to the previous settings. The "ESC" does not respond, while the cross button brings the default Mac setting.
Affected input device: Touch Bar,
Type of Mac: MacBook Pro, 2019
macOS version: macOS Mojave
Version 10.14.6 -
BetterTouchTool version:BetterTouchTool Version: 3.173
Additional information (e.g. StackTraces, related issues, screenshots, workarounds, etc.): Workaround:
To access the previous setting, ie the node before the group, I need to switch to a different app, back and forth.
