With the last version of BTT (3.373) and MacOs (10.15.5) some features of BTT related to touchbar are not working anymore and freezing BTT
Touchbar
Type of Mac: macbook pro
macOS version: 10.5.5
BetterTouchTool version: 3.373
default 10:11:14.474051-0300 BetterTouchTool *** Assertion failure in -NSEvent _initDigitizerTouchesFromIOHidEvent:window:contextID: , /AppleInternal/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1894.50.103/AppKit.subproj/NSEvent.m:1607
error 10:11:14.474225-0300 BetterTouchTool 612969074.474028 Missing Touches. This is a bug in IOHIDFamily
error 10:11:14.475568-0300 BetterTouchTool (
0 CoreFoundation 0x00007fff2ff24be7 __exceptionPreprocess + 250
1 libobjc.A.dylib 0x00007fff68cfc5bf objc_exception_throw + 48
2 CoreFoundation 0x00007fff2ff4dd98 +[NSException raise:format:arguments:] + 88
3 Foundation 0x00007fff3267b3b6 -[NSAssertionHandler handleFailureInFunction:file:lineNumber:description:] + 166
4 AppKit 0x00007fff2d701d16 -[NSEvent _initDigitizerTouchesFromIOHidEvent:window:contextID:] + 1458
5 AppKit 0x00007fff2d2c0609 -[NSEvent _initWithCGEvent:eventRef:] + 3729
6 AppKit 0x00007fff2d11c18b -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1635
7 AppKit 0x00007fff2d10dd7e -[NSApplication run] + 658
8 AppKit 0x00007fff2d0dfb86 NSApplicationMain + 777
9 libdyld.dylib 0x00007fff69ea3cc9 start + 1
10 ??? 0x0000000000000001 0x0 + 1
default 10:11:14.488987-0300 BetterTouchTool *** Assertion failure in -NSEvent _initDigitizerTouchesFromIOHidEvent:window:contextID: , /AppleInternal/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1894.50.103/AppKit.subproj/NSEvent.m:1607
error 10:11:14.489180-0300 BetterTouchTool 612969074.488962 Missing Touches. This is a bug in IOHIDFamily
error 10:11:14.490497-0300 BetterTouchTool (
what exactly do you mean by touch bar slide?
Two and three fingers swipe
The gestures seem to work fine here, have you already tried to restart your Mac?
What kind of action do you have assigned?
Yes, a couple of times.
Can I help you to debug sending my entire profile via email?
I've sent to you an email with my logs and profile. My actions are 3 fingers swipe to control volume and two fingers swipe to control brightness. First interaction works but after I remove my fingers from touchbar and try to start another gesture nothing works again. I need to switch back to mac os default touchbar or restart BTT.
I have tried multiple things but I'm unable to reproduce this ;-( (even with your debug data).
What kind of Macbook Pro do you own?
Maybe try enabling the "global" checkbox, if that's checked BTT will use a completely different gesture recognition technique.
Macbook Pro 15" 2018.
My flow to reproduce was: three fingers gesture forward and backward, wait for a second two fingers swipe forward and backward. Repeat that process and nothing works anymore.
With global checkbox enabled the bug doesn't occur and shows the line again when I do the swipe gesture. At least, now I have a workaround.
I have tried that for minutes here but am unable to get it to fail ;-( (MBP 2019)
Looking at the crashlog I believe this might be some weird Apple bug as BTT doesn't really appear in the stacktrace. I'll keep monitoring this!
Process: BetterTouchTool [25676]
Path: /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
Identifier: com.hegenberg.BetterTouchTool
Version: 3.389 (1612)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: BetterTouchTool [25676]
User ID: 501
Date/Time: 2020-06-16 19:39:50.374 -0300
OS Version: Mac OS X 10.15.5 (19F101)
Report Version: 12
Bridge OS Version: 3.0 (14Y908)
Anonymous UUID: DCDE16E4-71DF-4CDC-9769-0D43E96243FC
Time Awake Since Boot: 200000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff70d5133a __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff70e0de60 pthread_kill + 430
2 libsystem_c.dylib 0x00007fff70cd8808 abort + 120
3 com.hegenberg.BetterTouchTool 0x0000000109242ba4 -[BTTApplication _crashOnException:].cold.1 + 154
4 com.hegenberg.BetterTouchTool 0x0000000108dca08d -[BTTApplication _crashOnException:] + 345
5 com.apple.AppKit 0x00007fff34265a26 -[NSApplication reportException:] + 901
6 com.apple.AppKit 0x00007fff33e73e30 -[NSApplication run] + 836
7 com.apple.AppKit 0x00007fff33e45b86 NSApplicationMain + 777
8 libdyld.dylib 0x00007fff70c09cc9 start + 1
Thread 1:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x00007fff70d4adfa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff70d4b170 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff36c0ef85 __CFRunLoopServiceMachPort + 247
3 com.apple.CoreFoundation 0x00007fff36c0da52 __CFRunLoopRun + 1319
4 com.apple.CoreFoundation 0x00007fff36c0cece CFRunLoopRunSpecific + 462
5 com.apple.CFNetwork 0x00007fff3544702a 0x7fff353fd000 + 303146
6 com.apple.Foundation 0x00007fff3929d7a2 __NSThread__start__ + 1064
7 libsystem_pthread.dylib 0x00007fff70e0e109 _pthread_start + 148
8 libsystem_pthread.dylib 0x00007fff70e09b8b thread_start + 15
Thread 2:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff34025144 _NSEventThread + 132
6 libsystem_pthread.dylib 0x00007fff70e0e109 _pthread_start + 148
7 libsystem_pthread.dylib 0x00007fff70e09b8b thread_start + 15
Thread 3:: Dispatch queue: cocoa.lumberjack.fileLogger
0 com.apple.CoreFoundation 0x00007fff36bbc256 __CFStringAppendFormatCore + 12990
1 com.apple.CoreFoundation 0x00007fff36bb8f1c _CFStringCreateWithFormatAndArgumentsAux2 + 149
2 com.apple.Foundation 0x00007fff3925fe20 +[NSString stringWithFormat:] + 153
3 com.hegenberg.BetterTouchTool 0x0000000108f02ac9 -[DDFileLogger logMessage:] + 87
4 com.hegenberg.BetterTouchTool 0x0000000108f066d5 __16-[DDLog lt_log:]_block_invoke + 43
5 libdispatch.dylib 0x00007fff70baf6c4 _dispatch_call_block_and_release + 12
6 libdispatch.dylib 0x00007fff70bb0658 _dispatch_client_callout + 8
7 libdispatch.dylib 0x00007fff70bb5d7e _dispatch_lane_serial_drain + 911
8 libdispatch.dylib 0x00007fff70bb65d6 _dispatch_lane_invoke + 363
9 libdispatch.dylib 0x00007fff70bbfc09 _dispatch_workloop_worker_thread + 596
10 libsystem_pthread.dylib 0x00007fff70e0aa3d _pthread_wqthread + 290
11 libsystem_pthread.dylib 0x00007fff70e09b77 start_wqthread + 15
Thread 4:
0 libsystem_pthread.dylib 0x00007fff70e09b68 start_wqthread + 0
Thread 5:
Thread 6:: Dispatch queue: cocoa.lumberjack
0 libsystem_kernel.dylib 0x00007fff70d4c55e __ulock_wait + 10
1 libdispatch.dylib 0x00007fff70bb0e29 _dlock_wait + 44
2 libdispatch.dylib 0x00007fff70bb10b7 _dispatch_group_wait_slow + 43
3 com.hegenberg.BetterTouchTool 0x0000000108f06508 -[DDLog lt_log:] + 459
4 com.hegenberg.BetterTouchTool 0x0000000108f04b2c __40-[DDLog queueLogMessage:asynchronously:]_block_invoke + 58
7 libdispatch.dylib 0x00007fff70bb5c44 _dispatch_lane_serial_drain + 597
Thread 7:
5 com.apple.CoreFoundation 0x00007fff36c95519 CFRunLoopRun + 40
6 com.apple.MultitouchSupport.framework 0x00007fff5dc999c6 mt_ThreadedMTEntry + 71
Thread 8:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x000000011301adc0 rcx: 0x00007ffee715a878 rdx: 0x0000000000000000
rdi: 0x0000000000000307 rsi: 0x0000000000000006 rbp: 0x00007ffee715a8a0 rsp: 0x00007ffee715a878
r8: 0x0000000000000001 r9: 0x00000000000007fb r10: 0x000000011301adc0 r11: 0x0000000000000246
r12: 0x0000000000000307 r13: 0x7fffffffffffffff r14: 0x0000000000000006 r15: 0x0000000000000016
rip: 0x00007fff70d5133a rfl: 0x0000000000000246 cr2: 0x00000001c6977020
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x108aa5000 - 0x1093c9ff7 +com.hegenberg.BetterTouchTool (3.389 - 1612) <60F6907E-E9F1-320B-96C1-149BCAE0BDAC> /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
0x10a3e2000 - 0x10a465ff7 +com.mixedinkey.MIKMIDI (1.5 - 877) <5CE361C9-9E8D-37E9-B022-24BFF71F12A2> /Applications/BetterTouchTool.app/Contents/Frameworks/MIKMIDI.framework/Versions/A/MIKMIDI
0x10a4eb000 - 0x10a4faff7 +net.wafflesoftware.ShortcutRecorder.framework.Leopard (1.0) <63542887-8F80-387F-A49B-90D3D630F667> /Applications/BetterTouchTool.app/Contents/Frameworks/ShortcutRecorder.framework/Versions/A/ShortcutRecorder
0x10a514000 - 0x10a5bdfff +com.mentalfaculty.ensembles (2.6 - 1) <E7B68A6E-1DD2-38BA-948F-8EE663634E61> /Applications/BetterTouchTool.app/Contents/Frameworks/Ensembles.framework/Versions/A/Ensembles
0x10a61f000 - 0x10a661fff +org.sparkle-project.Sparkle (1.18.1 14071-g6b01db6f4 - 1.18.1) <1522A52C-5418-3863-816B-BED4C543E67E> /Applications/BetterTouchTool.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x10a6ab000 - 0x10a6acfff +com.hegenberg.BTTPluginSupport (1.0 - 1) <86B7767F-BF19-36AB-B81C-764D0CE7D56F> /Applications/BetterTouchTool.app/Contents/Frameworks/BTTPluginSupport.framework/Versions/A/BTTPluginSupport
0x10a6bf000 - 0x10a6c6fff +com.potionfactory.LetsMove (1.21 - 1.21) <300E0114-3781-356C-938F-A9430CEBA497> /Applications/BetterTouchTool.app/Contents/Frameworks/LetsMove.framework/Versions/A/LetsMove
0x10c550000 - 0x10c566ff7 com.apple.security.csparser (3.0 - 59306.120.7) <C5CDF137-052A-363E-B9E7-1128E27B3B7E> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x10dab6000 - 0x10dab9047 libobjc-trampolines.dylib (787.1) <8212B354-A106-3806-A022-A60F2B2FA5C9> /usr/lib/libobjc-trampolines.dylib
0x10db9b000 - 0x10dbaeff3 com.apple.iokit.IOHIDLib (2.0.0 - 2.0.0) <9F6A72D6-9A3D-36D7-8BD2-30D3FBBE8A0C> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
0x112f50000 - 0x112fe1eff dyld (750.5) <E4698FBD-806A-3396-B279-E685BA37430B> /usr/lib/dyld
0x7fff29c7d000 - 0x7fff29ecaff8 com.apple.RawCamera.bundle (9.02.0 - 1350.29) <0CC24FF1-0754-3A75-BA2D-212CF70ADDC1> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff29ecd000 - 0x7fff29ffbff0 com.apple.AMDMTLBronzeDriver (3.9.15 - 3.0.9) <D901C675-0E10-38B7-975A-82BB92383B60> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fff2f58f000 - 0x7fff2f98eff1 com.apple.driver.AppleIntelKBLGraphicsMTLDriver (14.6.18 - 14.0.6) <568AB53D-A275-3FAC-932C-A32C3E277CA3> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
0x7fff3242e000 - 0x7fff32629ffb com.apple.avfoundation (2.0 - 1850.2) <4820F165-5E20-3120-913D-C047FDB68392> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff3262a000 - 0x7fff326f6ffe com.apple.audio.AVFAudio (1.0 - 415.72) <C0FE6926-F8E6-339A-9D11-C6E3BEE688BF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff32816000 - 0x7fff32816fff com.apple.Accelerate (1.11 - Accelerate 1.11) <56DFF715-6A4E-3231-BDCC-A348BCB05047> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff32817000 - 0x7fff3282dfef libCGInterfaces.dylib (524.2.1) <A423F932-C044-3CEB-BF20-BF4CB323361E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff3282e000 - 0x7fff32e84fff com.apple.vImage (8.1 - 524.2.1) <17C93AB9-1625-3FDB-9851-C5E77BBE3428> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff32e85000 - 0x7fff330ecff7 libBLAS.dylib (1303.60.1) <CBC28BE4-3C78-3AED-9565-0D625251D121> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff330ed000 - 0x7fff335c0fef libBNNS.dylib (144.100.2) <8D653678-1F9B-3670-AAE2-46DFB8D37643> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff335c1000 - 0x7fff3395cfff libLAPACK.dylib (1303.60.1) <F8E9D081-7C60-32EC-A47D-2D30CAD73C5F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff3395d000 - 0x7fff33972fec libLinearAlgebra.dylib (1303.60.1) <D2C1ACEA-2B6A-339A-9EEB-62A76CC92CBE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff33973000 - 0x7fff33978ff3 libQuadrature.dylib (7) <3112C977-8306-3190-8313-01A952B7F3CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff33979000 - 0x7fff339e9fff libSparse.dylib (103) <40510BF9-99A7-3155-A81D-6DE5A0C73EDC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff339ea000 - 0x7fff339fcfef libSparseBLAS.dylib (1303.60.1) <3C1066AB-20D5-38D2-B1F2-70A03DE76D0B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff339fd000 - 0x7fff33bd4fd7 libvDSP.dylib (735.121.1) <74702E2E-ED05-3765-B18C-64BEFF62B517> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff33bd5000 - 0x7fff33c97fef libvMisc.dylib (735.121.1) <137558BF-503D-3A6E-96DC-A181E3FB31FF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff33c98000 - 0x7fff33c98fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <D7E8E400-35C8-3174-9956-8D1B483620DA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff33c99000 - 0x7fff33cf8ff0 com.apple.Accounts (113 - 113) <0510C893-F1F2-38B2-B3AA-A30DB2F5B688> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff33e42000 - 0x7fff34c02ffd com.apple.AppKit (6.9 - 1894.50.103) <61269B8C-C432-335F-8894-B95C235A41A5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff34c41000 - 0x7fff34c51fff com.apple.AppleScriptObjC (1.4 - 35) <A144CC7E-885D-3CA7-89BC-49583EB9C327> /System/Library/Frameworks/AppleScriptObjC.framework/Versions/A/AppleScriptObjC
0x7fff34c52000 - 0x7fff34c52fff com.apple.ApplicationServices (48 - 50) <EEC73694-1A37-3C14-A839-6991E2BD8655> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff34c53000 - 0x7fff34cbefff com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <A6912C4A-55CC-3701-BACA-E63423B99481> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff34d57000 - 0x7fff34d95ff0 libFontRegistry.dylib (274.0.5.1) <A78A7869-C96C-3AD6-A038-DE541639BB60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff34df0000 - 0x7fff34e1ffff com.apple.ATSUI (1.0 - 1) <4B3C2201-DBB3-352C-936B-9C423122EFF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff34e20000 - 0x7fff34e24ffb com.apple.ColorSyncLegacy (4.13.0 - 1) <47D42CDE-2E9A-3AF6-9365-1BFD1189196B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff34ebe000 - 0x7fff34f15ffa com.apple.HIServices (1.22 - 675.1) <273492E3-FF0F-3A8A-A83F-0F11F99B5F26> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff34f16000 - 0x7fff34f24fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <DA175323-5BE3-3C54-92D4-A171A4A067E6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff34f25000 - 0x7fff34f6affa com.apple.print.framework.PrintCore (15.4 - 516.2) <99AEBCDB-2DCA-3A13-906F-7F0D7962B002> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff34f6b000 - 0x7fff34f75ff7 com.apple.QD (4.0 - 413) <D2E1DC80-D26F-3508-BBA5-B8AE7ED6CB0E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff34f76000 - 0x7fff34f83ffc com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <823C0DE7-1351-3B39-8F06-AB5FCAD2C874> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff34f84000 - 0x7fff35065ffa com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <75651F0A-F2CE-3F68-B86A-E66B8815DCF4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff35067000 - 0x7fff35067fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <E51DCB3C-CF4F-320B-AC86-D445E30C0891> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff351c8000 - 0x7fff353cfff7 com.apple.AutomatorFramework (2.10 - 492) <846FEE94-E343-3FE7-931F-1B1A2EE5DB38> /System/Library/Frameworks/Automator.framework/Versions/A/Automator
0x7fff353fd000 - 0x7fff3578bffd com.apple.CFNetwork (1126 - 1126) <BB8F4C63-10B8-3ACD-84CF-D4DCFA9245DD> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff35807000 - 0x7fff35807fff com.apple.Carbon (160 - 162) <4F1F60CB-6C1E-3D79-832E-8D606601F282> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff35808000 - 0x7fff3580bff3 com.apple.CommonPanels (1.2.6 - 101) <333BBF55-AF23-3B99-A9FF-7906175B9406> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff3580c000 - 0x7fff35b00ff3 com.apple.HIToolbox (2.1.1 - 994.6) <5C44ACA7-D158-3F9B-8F88-0477510D44FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff35b01000 - 0x7fff35b04ff3 com.apple.help (1.3.8 - 71) <4B2701A0-8813-35F8-82F8-676B184D15C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff35b05000 - 0x7fff35b0aff7 com.apple.ImageCapture (9.0 - 1600.60.4.2) <20872A2D-CBF9-38E6-BD16-C1D387120651> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff35b0b000 - 0x7fff35b0bfff com.apple.ink.framework (10.15 - 227) <5B60FDDE-D60E-326B-BD3D-6EA5FA1CBB76> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff35b0c000 - 0x7fff35b26ffa com.apple.openscripting (1.7 - 185.1) <E59F893B-1A73-3098-8924-79227EC9787E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff35b47000 - 0x7fff35b47fff com.apple.print.framework.Print (15 - 271) <07C50BF6-2222-3769-A5B8-79D7F996183F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff35b48000 - 0x7fff35b4aff7 com.apple.securityhi (9.0 - 55008) <D7017D5A-4206-3E2F-9F8E-0F932422CA87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff35b4b000 - 0x7fff35b51fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1188E643-967C-334E-BC1A-60A0F82C67E5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff35b52000 - 0x7fff35ceaffa com.apple.cloudkit.CloudKit (867 - 867) <C68C376E-E2CF-34FE-BC1F-B254233F980D> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff35ceb000 - 0x7fff35cebfff com.apple.Cocoa (6.11 - 23) <87426C3A-7C6C-39D0-905C-C591B997029E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff35cf9000 - 0x7fff35deffff com.apple.ColorSync (4.13.0 - 3394.9) <61698A7B-BB8C-3891-9547-703FF84671A8> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff35ee1000 - 0x7fff3601aff6 com.apple.contacts (1.0 - 3455.18) <3AE8C882-BFD4-3DA0-825E-D8560623E63A> /System/Library/Frameworks/Contacts.framework/Versions/A/Contacts
0x7fff360da000 - 0x7fff365e3ffb com.apple.audio.CoreAudio (5.0 - 5.0) <62BEE4B7-8A26-3951-9D78-4E193617AF7A> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff36636000 - 0x7fff3666efff com.apple.CoreBluetooth (1.0 - 1) <6BC7F863-4495-371F-BC54-543E5CFE1665> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff3666f000 - 0x7fff36a59fe8 com.apple.CoreData (120 - 977.3) <D902A2E3-1D0A-3995-974E-A526976E5735> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff36a5a000 - 0x7fff36b8affe com.apple.CoreDisplay (1.0 - 186.6.12) <EA74CC46-8715-3B90-95E8-4594D2F0CC8A> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff36b8b000 - 0x7fff3700affb com.apple.CoreFoundation (6.9 - 1676.105) <6AF8B3CC-BC3F-3869-B9FB-1D881422364E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff3700c000 - 0x7fff37680ff8 com.apple.CoreGraphics (2.0 - 1355.17) <E1CE3919-F36B-309F-89BA-79F36DC8125E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff3768e000 - 0x7fff379e9ff0 com.apple.CoreImage (15.0.0 - 940.9) <44F68E8C-315A-32A6-BB19-7F24C00AB347> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff379ea000 - 0x7fff37a53ff0 com.apple.corelocation (2394.0.22 - 2394.0.22) <B1E3382A-62ED-36F0-AB86-F46D7B7FF9AE> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff37a54000 - 0x7fff37aa4ff6 com.apple.audio.midi.CoreMIDI (1.10 - 88) <E35AE117-37C5-3AD5-A38F-C43D1F6EE1E6> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x7fff37aa7000 - 0x7fff37da9ff2 com.apple.CoreML (1.0 - 1) <06598905-BA5B-3D89-9921-39C6D5889DD9> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
0x7fff37daa000 - 0x7fff37e85ffc com.apple.CoreMedia (1.0 - 2620.11.40.2) <0F490101-ED30-3189-B099-E247B6361A0B> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff37e86000 - 0x7fff37ee8ffe com.apple.CoreMediaIO (1000.0 - 5125.6) <9435B82E-4728-362C-9FF0-E8AEC19D6E3C> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff37f72000 - 0x7fff37f72fff com.apple.CoreServices (1069.24 - 1069.24) <D9F6AB40-10EC-3682-A969-85560E2E4768> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff37f73000 - 0x7fff37ff8fff com.apple.AE (838.1 - 838.1) <5F26DA9B-FB2E-3AF8-964B-63BD6671CF12> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff37ff9000 - 0x7fff382daff7 com.apple.CoreServices.CarbonCore (1217 - 1217) <8022AF47-AA99-3786-B086-141D84F00387> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff382db000 - 0x7fff38328ffd com.apple.DictionaryServices (1.2 - 323.6) <C0F3830C-A4C6-3046-9A6A-DE1B5D448C2C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff38329000 - 0x7fff38331ff7 com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <E4B2CAF2-1203-335F-9971-1278CB6E2AE0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff38332000 - 0x7fff3856cff6 com.apple.LaunchServices (1069.24 - 1069.24) <2E0AD228-B1CC-3645-91EE-EB7F46F2147B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff3856d000 - 0x7fff38605ff1 com.apple.Metadata (10.7.0 - 2076.6) <C8034E84-7DD4-34B9-9CDF-16A05032FF39> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff38606000 - 0x7fff38633fff com.apple.CoreServices.OSServices (1069.24 - 1069.24) <72FDEA52-7607-3745-AC43-630D80962099> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff38634000 - 0x7fff3869bfff com.apple.SearchKit (1.4.1 - 1.4.1) <086EB5DF-A2EC-3342-8028-CA7996BE5CB2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff3869c000 - 0x7fff386c0ff5 com.apple.coreservices.SharedFileList (131.4 - 131.4) <AE333DA2-C279-3751-8C15-B963E58EE61E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff386c1000 - 0x7fff38732fff com.apple.CoreSpotlight (1.0 - 2076.6) <A722F723-26A0-305D-96D9-6CCE7A0D75A1> /System/Library/Frameworks/CoreSpotlight.framework/Versions/A/CoreSpotlight
0x7fff3891d000 - 0x7fff389e4ffc com.apple.CoreTelephony (113 - 7560.1) <BAC6EEA9-89A0-3D03-BE0B-C65A3838C9D0> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
0x7fff389e5000 - 0x7fff38b9cffc com.apple.CoreText (643.1.5.1 - 643.1.5.1) <715FE3F7-E8FB-3997-85A0-3AB2839F6C30> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff38b9d000 - 0x7fff38be1ffb com.apple.CoreVideo (1.8 - 344.3) <A200AFC7-2CB2-30CD-8B2A-1269CA64A29B> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff38be2000 - 0x7fff38c6fffc com.apple.framework.CoreWLAN (13.0 - 1601.2) <855E51AA-DF3A-3BB9-A4F0-6880D42B8762> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff38e2b000 - 0x7fff38e36ff7 com.apple.DirectoryService.Framework (10.15 - 220.40.1) <06D98FD0-796F-356F-B492-A6D8F3D5BEC0> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff38e37000 - 0x7fff38ee1ff0 com.apple.DiscRecording (9.0.3 - 9030.4.5) <D9033DDA-E4C8-36FB-AE60-4EF66F4F1F9E> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff38f06000 - 0x7fff38f0cfff com.apple.DiskArbitration (2.7 - 2.7) <52E7D181-2A18-37CD-B24F-AA32E93F7A69> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff38f31000 - 0x7fff390deffc com.apple.ical.EventKit (3.0 - 1370.5.1) <F49642CA-0C8D-3904-A65D-E074EC1806B0> /System/Library/Frameworks/EventKit.framework/Versions/A/EventKit
0x7fff390ff000 - 0x7fff3922dff6 com.apple.FileProvider (304.1 - 304.1) <58D64236-947E-3E6A-85E6-C66AEF9E0EE0> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff39245000 - 0x7fff3960afff com.apple.Foundation (6.9 - 1676.105) <1FA28BAB-7296-3A09-8E1E-E62A7D233DB8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff3960c000 - 0x7fff39633ffe com.apple.GLKit (118 - 118) <E6E41E1A-16BA-3351-B465-9AC22C33FEF3> /System/Library/Frameworks/GLKit.framework/Versions/A/GLKit
0x7fff39677000 - 0x7fff396c7ff7 com.apple.GSS (4.0 - 2.0) <4E241C00-42A5-3572-9430-D950FBB7A4A0> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff39804000 - 0x7fff39918ff3 com.apple.Bluetooth (7.0.5 - 7.0.5f6) <5897C368-9674-3E34-B144-FFB06A2DF37B> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff3997e000 - 0x7fff39a22ff3 com.apple.framework.IOKit (2.0.2 - 1726.121.1) <A0F54725-036F-3279-A46E-C2ABDBFD479B> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff39a24000 - 0x7fff39a35ffb com.apple.IOSurface (269.11 - 269.11) <D3CC2AA1-4AE2-30EE-A9DB-C04CCAA88ADE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff39a53000 - 0x7fff39ab3ff7 com.apple.ImageCaptureCore (1.0 - 1600.60.4.2) <8BA11284-66A0-3567-A13C-72AD1CC0C2EA> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff39ab4000 - 0x7fff39c10ffe com.apple.ImageIO.framework (3.3.0 - 1976.6) <5B4C2E04-9161-3C82-A7FB-F4D51E3C1E10> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff39c11000 - 0x7fff39c14fff libGIF.dylib (1976.6) <3B26EE1C-C570-305C-A9A3-EA62D2F2E7B8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff39c15000 - 0x7fff39ccefff libJP2.dylib (1976.6) <EB4E4E09-DD81-3E6B-A513-3667E810AEF3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff39ccf000 - 0x7fff39cf2fe3 libJPEG.dylib (1976.6) <9D7FAC55-85A6-34AB-9F26-0BCA381E8CE7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff39f6e000 - 0x7fff39f88fef libPng.dylib (1976.6) <4886A1F8-E9CA-38F2-BF2F-1FCA1DFDD1C9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff39f89000 - 0x7fff39f8afff libRadiance.dylib (1976.6) <FA759D33-131A-33B8-943E-32409F162738> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff39f8b000 - 0x7fff39fd4fff libTIFF.dylib (1976.6) <E9994BF8-6CF5-3422-B4FD-A14DC390EF12> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff39fed000 - 0x7fff3a47cff8 com.apple.Intents (1.0 - 1) <EA4EEE84-D337-3C59-9C02-261205CA04E7> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
0x7fff3a47f000 - 0x7fff3b51ffe9 com.apple.JavaScriptCore (15609 - 15609.2.9.1.2) <62158DFB-C250-3A18-AE52-6296544AEA43> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff3b536000 - 0x7fff3b548ff3 com.apple.Kerberos (3.0 - 1) <AE0E56CA-D924-3CC8-BBAA-8C6EEC3038BE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff3b549000 - 0x7fff3b549fff libHeimdalProxy.dylib (77) <A970C7A8-7CCD-3701-A459-078BD5E8FE4E> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff3b54a000 - 0x7fff3b580ff7 com.apple.LDAPFramework (2.4.28 - 194.5) <4CFB6351-53B9-36AF-B654-AE636BBC361A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff3b8db000 - 0x7fff3b8e5ffb com.apple.MediaAccessibility (1.0 - 125.1) <DBF40A12-65A6-33E4-839C-292600B7D910> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff3b9b1000 - 0x7fff3c0feff5 com.apple.MediaToolbox (1.0 - 2620.11.40.2) <40F16AF6-79D1-3C2E-976C-E7E7870A4EF9> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff3c100000 - 0x7fff3c1caff7 com.apple.Metal (212.7 - 212.7) <CC7BF715-142B-3C2A-81AD-0E35693230F2> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff3c1cc000 - 0x7fff3c1e6ff5 com.apple.MetalKit (141.2 - 141.2) <8162AFB6-327C-3BE1-AEF7-2BEA999B1DFB> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fff3c1e7000 - 0x7fff3c224ff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <52089325-EC97-3EED-ABB3-9B39EC0BD429> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff3c225000 - 0x7fff3c2affe2 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <9E434EA0-6BCA-3903-B882-CEB69730A63B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff3c2b0000 - 0x7fff3c2d5ff4 com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <EDD6C3A5-E231-3FB1-B4D4-45742AFB9A4E> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff3c2d6000 - 0x7fff3c2ebffb com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <C5A2B865-5CE2-3E5D-8452-54639FCB0954> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff3c2ec000 - 0x7fff3c44affc com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <47CCDBAC-5843-366A-A68C-6E8851D0865D> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff3c44b000 - 0x7fff3c49aff4 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <302BDF8E-B00A-3123-A6C4-E262B7513CF6> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff3c49b000 - 0x7fff3c49cff5 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <14F84B42-9DA2-39A1-81B4-666B8020520C> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff3c4aa000 - 0x7fff3d49dff1 com.apple.ModelIO (217.43 - 217.43) <0D63CB21-0334-36BA-9121-4702F143B6E5> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
0x7fff3d523000 - 0x7fff3d52fffe com.apple.NetFS (6.0 - 4.0) <AC74E6A4-6E9B-3AB1-9577-8277F8A3EDE0> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff3d530000 - 0x7fff3d687ff3 com.apple.Network (1.0 - 1) <B5B8E999-BBCC-3DEF-8881-8FFF69F8EC4B> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff3d688000 - 0x7fff3d8e7ff5 com.apple.NetworkExtension (1.0 - 1) <446D0D36-E8F8-3F2C-B32B-5C3630177FBC> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
0x7fff3d92d000 - 0x7fff3d965ffa com.apple.OSAKit (1.5 - 107) <5327D975-C13A-3E74-8C2C-B548889E13F7> /System/Library/Frameworks/OSAKit.framework/Versions/A/OSAKit
0x7fff400b8000 - 0x7fff40110fff com.apple.opencl (3.5 - 3.5) <9B101D40-EA79-3C0D-B7AE-A3F18094B2D7> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff40111000 - 0x7fff4012dfff com.apple.CFOpenDirectory (10.15 - 220.40.1) <BFC32EBE-D95C-3267-B95C-5CEEFD189EA6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff4012e000 - 0x7fff40139ffd com.apple.OpenDirectory (10.15 - 220.40.1) <76A20BBA-775F-3E17-AB0F-FEDFCDCE0716> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff40a9f000 - 0x7fff40aa1fff libCVMSPluginSupport.dylib (17.10.22) <AAE07E0C-4B28-364B-A7D9-028C7CD14954> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff40aa2000 - 0x7fff40aa7fff libCoreFSCache.dylib (176.15) <609C5DFC-9A97-344D-BBC7-E0B08D862C63> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff40aa8000 - 0x7fff40aacfff libCoreVMClient.dylib (176.15) <8F8DD27F-AC7C-398D-A8E3-396F1528E317> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff40aad000 - 0x7fff40ab5ff7 libGFXShared.dylib (17.10.22) <D0649AB5-5331-328D-8141-E5A6F06D4AD7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff40ab6000 - 0x7fff40ac0fff libGL.dylib (17.10.22) <116DDBF7-D725-3B8C-BD0B-A21B758FE421> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff40ac1000 - 0x7fff40af5ff7 libGLImage.dylib (17.10.22) <2B314C76-C7E6-3AC5-9157-70B0529C1F9B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff40c8b000 - 0x7fff40cc7fff libGLU.dylib (17.10.22) <B29F73B2-B5A9-3C38-AF77-351173D2E3DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff41703000 - 0x7fff41712ff7 com.apple.opengl (17.10.22 - 17.10.22) <D5BF32A8-2E0A-345D-80A3-7CA7C2CF748D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff418c4000 - 0x7fff419b7ff0 com.apple.PDFKit (1.0 - 835.7) <346881D8-3E09-3787-B877-6284D1D3B24A> /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff419b8000 - 0x7fff41acfff9 com.apple.PencilKit (1.0 - 1) <AD3C6D86-17D6-35A3-AE5C-BEDB872197BF> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
0x7fff41d44000 - 0x7fff41d6fff7 com.apple.frameworks.preferencepanes (16.0 - 16.0) <AB86DD44-6E64-3AD2-BAA2-040B8E0A8DFD> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
0x7fff41d70000 - 0x7fff41d76ff6 com.apple.PushKit (1.0 - 1) <B4E45366-8C51-3248-BDAF-2ECFE94D5378> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
0x7fff41e97000 - 0x7fff420ddff7 com.apple.imageKit (3.0 - 1081) <F0AD8D71-D6BE-3ABC-9B5F-93825F3F96B1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff420de000 - 0x7fff4259dfff com.apple.QuartzComposer (5.1 - 378) <351442B3-92C1-30FB-B5BC-E64759CCA5FC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff4259e000 - 0x7fff425c3ffc com.apple.quartzfilters (1.10.0 - Tag) <F491CB46-3837-3525-AE31-23EB89692BA1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff425c4000 - 0x7fff426ceff7 com.apple.QuickLookUIFramework (5.0 - 906.2) <731A1F57-2064-3941-823E-2D23BD1D9CB1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff426cf000 - 0x7fff426cffff com.apple.quartzframework (1.5 - 23) <E2368AAF-5B01-328F-9D5D-9089CBB9C8FA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff426d0000 - 0x7fff42952ff9 com.apple.QuartzCore (1.11 - 841.2) <444E6F22-DFA6-391B-B51F-A96AE69E524D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff42953000 - 0x7fff429acff5 com.apple.QuickLookFramework (5.0 - 906.2) <E6F25D56-E003-3B3B-851B-1566C132E006> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff429ad000 - 0x7fff429e2ffc com.apple.QuickLookThumbnailing (1.0 - 1) <469201A4-C87A-335F-91C1-81055CF89844> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff42eb3000 - 0x7fff42ecbff0 com.apple.SafariServices.framework (15609 - 15609.2.9.1.2) <DBB58DF1-3DA2-3558-B185-B7DAAB005113> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff434ba000 - 0x7fff434d2ff5 com.apple.ScriptingBridge (1.4 - 79) <3B2DEA6C-AD17-3560-83FD-0E684BA6067A> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff434d3000 - 0x7fff4381cff1 com.apple.security (7.0 - 59306.120.7) <AEA33464-1507-36F1-8CAE-A86EB787F9B5> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff4381d000 - 0x7fff438a5ffb com.apple.securityfoundation (6.0 - 55236.60.1) <79289FE1-CB5F-3BEF-A33F-11A29A93A681> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff438a6000 - 0x7fff438d3ff7 com.apple.securityinterface (10.0 - 55139.120.1) <CBC1CC5B-6C24-3843-935F-052767FBB69D> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff438d4000 - 0x7fff438d8ff8 com.apple.xpc.ServiceManagement (1.0 - 1) <4194D29D-F0D4-33F8-839A-D03C6C62D8DB> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff44584000 - 0x7fff445f2ff7 com.apple.SystemConfiguration (1.19 - 1.19) <0CF8726A-BE41-3E07-B895-FBC44B75450E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff44871000 - 0x7fff44bf4ff4 com.apple.VideoToolbox (1.0 - 2620.11.40.2) <53E0D852-61CA-34FE-9A9B-788708ADE495> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff44e96000 - 0x7fff45633fff libwebrtc.dylib (7609.2.9.1.2) <6047B7DA-1F79-35D6-B65B-F936B0E389EE> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff45634000 - 0x7fff47895ff4 com.apple.WebCore (15609 - 15609.2.9.1.2) <06B06644-07F9-3D09-A50E-F14D70FF6670> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff47896000 - 0x7fff47aa2ffc com.apple.WebKitLegacy (15609 - 15609.2.9.1.2) <7580EF1B-F43B-3532-9340-AB20340D0850> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff47aa3000 - 0x7fff481a4ffa com.apple.WebKit (15609 - 15609.2.9.1.2) <5148A4E2-0C5A-3DFD-8A02-676D7CC6ED4F> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff48553000 - 0x7fff48618ff7 com.apple.APFS (1412.120.2 - 1412.120.2) <1E8FD511-FDC4-31A2-ACDE-EB5192032BC6> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff48c5f000 - 0x7fff48c6affc com.apple.accessibility.AXCoreUtilities (1.0 - 1) <9E0367E6-6A4F-31FE-A493-9F3DF7510CA0> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
0x7fff48ddb000 - 0x7fff48de3ff5 com.apple.AccessibilityBundles (1.0 - 131.5) <7A4B7097-CA15-3947-B465-D7D24FB6653E> /System/Library/PrivateFrameworks/AccessibilityBundles.framework/Versions/A/AccessibilityBundles
0x7fff48e0a000 - 0x7fff48e55ff1 com.apple.AccessibilitySharedSupport (1.0 - 1) <6A1E8842-610E-3C28-A729-BD0637AA37CB> /System/Library/PrivateFrameworks/AccessibilitySharedSupport.framework/Versions/A/AccessibilitySharedSupport
0x7fff48e56000 - 0x7fff48e56fff com.apple.AccessibilitySupport (2.0 - 214.5) <5607AE2F-439C-35FF-AE9B-C0F552D183EE> /System/Library/PrivateFrameworks/AccessibilitySupport.framework/Versions/A/AccessibilitySupport
0x7fff48e57000 - 0x7fff48e7eff0 com.apple.AccessibilityEvents (2.0 - 214.5) <C6EA51B1-FE13-30FA-A61F-248F96A8449F> /System/Library/PrivateFrameworks/AccessibilitySupport.framework/Versions/A/Frameworks/AccessibilityEvents.framework/Versions/A/AccessibilityEvents
0x7fff48e7f000 - 0x7fff48ecaff7 com.apple.AccessibilityFoundation (2.0 - 214.5) <7255DA7C-B449-31BC-BA9C-2AE6BCC839BD> /System/Library/PrivateFrameworks/AccessibilitySupport.framework/Versions/A/Frameworks/AccessibilityFoundation.framework/Versions/A/AccessibilityFoundation
0x7fff48ecb000 - 0x7fff48f05ff8 com.apple.AccessibilityKit (2.0 - 214.5) <41C7D782-8F97-314D-9EEC-6785BA9548ED> /System/Library/PrivateFrameworks/AccessibilitySupport.framework/Versions/A/Frameworks/AccessibilityKit.framework/Versions/A/AccessibilityKit
0x7fff48f06000 - 0x7fff48f41fff com.apple.AccessibilityVisuals (2.0 - 214.5) <FE6755A1-B635-360E-994A-F3A8465B1871> /System/Library/PrivateFrameworks/AccessibilitySupport.framework/Versions/A/Frameworks/AccessibilityVisuals.framework/Versions/A/AccessibilityVisuals
0x7fff48f63000 - 0x7fff49014ffe com.apple.accounts.AccountsDaemon (113 - 113) <2C275FCF-21AB-3C41-B347-3CF1DC45F8D3> /System/Library/PrivateFrameworks/AccountsDaemon.framework/Versions/A/AccountsDaemon
0x7fff495b7000 - 0x7fff4970cff0 com.apple.AddressBook.core (1.0 - 1) <87B9E331-49E1-3607-B813-E6C7C0C39579> /System/Library/PrivateFrameworks/AddressBookCore.framework/Versions/A/AddressBookCore
0x7fff49728000 - 0x7fff49729ff1 com.apple.AggregateDictionary (1.0 - 1) <B907CE7A-0122-3E63-BF39-0A242B0DD7C4> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff49b77000 - 0x7fff49cc2ff5 com.apple.AnnotationKit (1.0 - 325.9) <E9B0F74B-CB16-3E07-9015-8CBF158EB08D> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
0x7fff49cc3000 - 0x7fff49ce0ff4 com.apple.AppContainer (4.0 - 448.100.6) <9C2D0065-9B38-3D1C-A090-46F129A1B3CA> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff49d02000 - 0x7fff49d18ff3 com.apple.AppSSOCore (1.0 - 1) <699B20D0-F45C-3328-A7AB-C4BBC3025168> /System/Library/PrivateFrameworks/AppSSOCore.framework/Versions/A/AppSSOCore
0x7fff49d35000 - 0x7fff49d43ff7 com.apple.AppSandbox (4.0 - 448.100.6) <7DAB58B1-8176-3FB0-A7B0-8A38E118E90B> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff4a12d000 - 0x7fff4a192ff7 com.apple.AppSupport (1.0.0 - 29) <B9F52509-241A-3C17-A907-88FD89F60AFB> /System/Library/PrivateFrameworks/AppSupport.framework/Versions/A/AppSupport
0x7fff4a1be000 - 0x7fff4a1e2ffb com.apple.framework.Apple80211 (13.0 - 1610.1) <B4B80CD6-B38E-3748-B30B-5088CCE9A7A8> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff4a1e3000 - 0x7fff4a316ff3 com.apple.AppleAccount (1.0 - 1.0) <B0AB24E4-B4E2-31AD-9240-08753C38874F> /System/Library/PrivateFrameworks/AppleAccount.framework/Versions/A/AppleAccount
0x7fff4a4a0000 - 0x7fff4a4affd7 com.apple.AppleFSCompression (119.100.1 - 1.0) <2E75CF51-B693-3275-9A4F-40571D48745E> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff4a5ae000 - 0x7fff4a5b9ff7 com.apple.AppleIDAuthSupport (1.0 - 1) <F4651654-E24F-3BF4-8DDF-8F91E5219BA4> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff4a5ba000 - 0x7fff4a5faff1 com.apple.AppleIDSSOAuthentication (1.0 - 1) <7ABD2F0F-AEF4-32FD-B3DE-874BDB49F953> /System/Library/PrivateFrameworks/AppleIDSSOAuthentication.framework/Versions/A/AppleIDSSOAuthentication
0x7fff4a5fb000 - 0x7fff4a643ff7 com.apple.AppleJPEG (1.0 - 1) <4655FF70-9772-3D7C-8159-5A5E56C9F84B> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff4a644000 - 0x7fff4a654ff7 com.apple.AppleLDAP (10.15 - 52) <0CBD6C1D-B083-3858-988E-F9B3E03CA740> /System/Library/PrivateFrameworks/AppleLDAP.framework/Versions/A/AppleLDAP
0x7fff4aa06000 - 0x7fff4aa2cffb com.apple.aps.framework (4.0 - 4.0) <34F0F991-2D0F-3376-B5B2-BDED2108552A> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff4aa2d000 - 0x7fff4aa31ff7 com.apple.AppleSRP (5.0 - 1) <B683AD55-A121-31DD-9A87-3A31C35FEABF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff4aa32000 - 0x7fff4aa54fff com.apple.applesauce (1.0 - 16.25) <33B66B71-64A4-365D-9953-E0545E69A5E7> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff4ab13000 - 0x7fff4ab16ffb com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <92580EE3-74BF-3488-90ED-C8EBD7A1B4C3> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff4ab17000 - 0x7fff4ab67ff7 com.apple.AppleVAFramework (6.1.2 - 6.1.2) <39C3583D-C824-3168-B67A-498487FD03D9> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff4abb0000 - 0x7fff4abbfff9 com.apple.AssertionServices (1.0 - 223.100.31) <478D2004-9B84-3AE9-9A0B-0A0B68ED028F> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff4b101000 - 0x7fff4b4fcff8 com.apple.audio.AudioResourceArbitration (1.0 - 1) <9ABFE41A-FD01-3111-BA73-D2DD1BF96525> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff4b752000 - 0x7fff4b992fe0 com.apple.audio.AudioToolboxCore (1.0 - 1104.84) <FA17E892-6A1A-309D-95C7-30ACFC44319C> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff4b996000 - 0x7fff4bab2ff0 com.apple.AuthKit (1.0 - 1) <375C3886-5430-3C02-BD2C-4244BF490ABA> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff4bc6f000 - 0x7fff4bc78ff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <F070F440-27AB-3FCF-9602-F278C332CA01> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff4bc79000 - 0x7fff4bd1aff5 com.apple.backup.framework (1.11.5 - 1298.5.10) <637CA389-627A-365C-98C2-D297C47D6EE3> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff4bd1b000 - 0x7fff4bda7ff6 com.apple.BaseBoard (466.3 - 466.3) <1718A41A-9923-3FD0-96B8-82376E153D27> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff4bdc6000 - 0x7fff4bdccffa com.apple.BezelServicesFW (336 - 336) <AA0244F5-E77A-38B5-8A4D-ACFD516C3855> /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
0x7fff4bea9000 - 0x7fff4bee5ff7 com.apple.bom (14.0 - 219.2) <586F1D9C-23B0-3F38-9C5B-728E9DD8B953> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff4c003000 - 0x7fff4c03aff5 com.apple.C2 (1.3 - 495) <4C624CDB-C2A8-3039-BC45-224FB8671969> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
0x7fff4c166000 - 0x7fff4c1c0ff2 com.apple.CalDAV (8.0 - 790.4.1) <34AA3D86-91A1-37DC-AD24-D967E12F749D> /System/Library/PrivateFrameworks/CalDAV.framework/Versions/A/CalDAV
0x7fff4c370000 - 0x7fff4c39bfff com.apple.CalendarAgentLink (8.0 - 250) <01598086-CEA8-35D5-AE14-F5166F77CA81> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
0x7fff4c3b4000 - 0x7fff4c42cff6 com.apple.CalendarFoundation (8.0 - 1140.5.1) <D675AA60-49D8-3A02-93D6-552A9315DFB7> /System/Library/PrivateFrameworks/CalendarFoundation.framework/Versions/A/CalendarFoundation
0x7fff4c463000 - 0x7fff4c75bffe com.apple.CalendarPersistence (8.0 - 1040.5.1) <4A3FD0EB-9008-3CC3-A16B-2E6D0FF102EE> /System/Library/PrivateFrameworks/CalendarPersistence.framework/Versions/A/CalendarPersistence
0x7fff4ca64000 - 0x7fff4cab3fff com.apple.ChunkingLibrary (307 - 307) <32E0F1A1-9DD6-3B52-91C2-93643041AA60> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff4cab4000 - 0x7fff4cb21ff7 com.apple.ClassKit (1.2 - 145.5.14) <0CECE939-7E04-3420-81D9-7B0FEC01C822> /System/Library/PrivateFrameworks/ClassKit.framework/Versions/A/ClassKit
0x7fff4cc0d000 - 0x7fff4cc98ff8 com.apple.CloudDocs (1.0 - 698.14) <4CFF0DF0-8A89-3DAD-8A07-A208FDDD163B> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff4d95a000 - 0x7fff4d96affb com.apple.CommonAuth (4.0 - 2.0) <91EC83B5-857D-3D4F-93B1-AAD7E0E029D8> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff4d97e000 - 0x7fff4d995fff com.apple.commonutilities (8.0 - 900) <12C6DEE5-1740-39A5-9711-6F815C6D77BD> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff4dc29000 - 0x7fff4dc65ffa com.apple.contacts.ContactsAutocomplete (1.0 - 1138) <E9F93D9C-F52B-3DDE-BE6D-B3FF87010FF9> /System/Library/PrivateFrameworks/ContactsAutocomplete.framework/Versions/A/ContactsAutocomplete
0x7fff4dc96000 - 0x7fff4dd1aff1 com.apple.AddressBook.ContactsFoundation (8.0 - 1118.8) <DCC917B9-DACB-3615-A02C-BF2582325901> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff4dd1b000 - 0x7fff4dd58ff0 com.apple.contacts.ContactsPersistence (1.0 - 3455.18) <A77AA554-340B-3478-A16E-F1FD0C1DD08B> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff4e099000 - 0x7fff4e46efc8 com.apple.CoreAUC (283.0.0 - 283.0.0) <BA9522E5-95D0-30D0-BEF4-691CEB51035B> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff4e46f000 - 0x7fff4e49cff7 com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <14FC549B-86BD-396A-B03E-6F5219482943> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff4e4bf000 - 0x7fff4e4deffc com.apple.analyticsd (1.0 - 1) <A4F653CA-2FD6-348B-B7B3-48D91A67508A> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff4e5e7000 - 0x7fff4e65dff7 com.apple.corebrightness (1.0 - 1) <D1E20AF2-A96B-318C-9605-9A3BD6EC27C2> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
0x7fff4e757000 - 0x7fff4e7e8ffe com.apple.coredav (1.0.1 - 870.4.1) <7AB7ACCC-E607-35FF-AC85-6CBEB63BF939> /System/Library/PrivateFrameworks/CoreDAV.framework/Versions/A/CoreDAV
0x7fff4e7e9000 - 0x7fff4e7f4ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <8F8E586D-C153-3ABA-88B7-6CEC7F476F0E> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff4e7f5000 - 0x7fff4ea00ff1 com.apple.CoreDuet (1.0 - 1) <C933EE99-D7D2-32F8-8B96-938A0FB612FB> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff4ea01000 - 0x7fff4ea4eff3 com.apple.coreduetcontext (1.0 - 1) <64FD6DBA-89E3-34FC-A758-3240D4737F75> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
0x7fff4ea4f000 - 0x7fff4ea5fffe com.apple.CoreDuetDaemonProtocol (1.0 - 1) <00D3E768-CBBF-36DE-B8D8-218F7B562F6F> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff4ea62000 - 0x7fff4ea64fff com.apple.CoreDuetDebugLogging (1.0 - 1) <DBE17F86-59D6-368D-AEF1-4BDF85D2E735> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff4ea75000 - 0x7fff4ea85ff3 com.apple.CoreEmoji (1.0 - 107.1) <CDCCB4B0-B98F-38E8-9568-C81320E756EB> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff4ec3b000 - 0x7fff4ed88fff com.apple.CoreHandwriting (161 - 1.2) <7F6BAABE-71D0-34F6-876D-C6C53331B5F3> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
0x7fff4f0c5000 - 0x7fff4f12fff0 com.apple.CoreNLP (1.0 - 213) <40FC46D2-844C-3282-A8E4-69DD827F05C5> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff4f3ed000 - 0x7fff4f3f1ffb com.apple.CoreOptimization (1.0 - 1) <5B3AA81A-F8DF-3688-85FC-9A9517720DA7> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff4f3f2000 - 0x7fff4f47affe com.apple.CorePDF (4.0 - 518.4.1) <98F39D44-028B-3714-AC76-0884D08DD6CF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff4f55d000 - 0x7fff4f565ff8 com.apple.CorePhoneNumbers (1.0 - 1) <B2CE100D-B82F-3481-86F6-7F85FF8BFAFB> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff4f566000 - 0x7fff4f5b894b com.apple.CorePrediction (1.0 - 1) <CED11BE0-808C-39C5-9FCE-29368322E9B1> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff4fe79000 - 0x7fff4fe84ffa com.apple.corerecents (1.0 - 1) <BF65E868-9691-340A-9731-B9287A112398> /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/CoreRecents
0x7fff4ff52000 - 0x7fff4ff75fff com.apple.CoreSVG (1.0 - 129) <3141D198-0507-3F72-A2C9-752EAFE3EEB3> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff4ff76000 - 0x7fff4ffa9fff com.apple.CoreServicesInternal (446.7 - 446.7) <B2CEC515-2225-3CB1-B34A-904AAEA54FDF> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff4ffaa000 - 0x7fff4ffd8ffd com.apple.CSStore (1069.24 - 1069.24) <C96E5CE8-D604-3F13-B079-B2BA33B90081> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff5015d000 - 0x7fff50200fff com.apple.CoreSuggestions (1.0 - 1052.34) <15988CF7-6F2C-3955-ACA9-970DBB572608> /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/CoreSuggestions
0x7fff504fd000 - 0x7fff50593ff7 com.apple.CoreSymbolication (11.4 - 64535.33.2) <0E7A1529-C737-33FD-AA7D-A32EB8B192DA> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff5062b000 - 0x7fff50757ff6 com.apple.coreui (2.1 - 609.4) <9B93CC42-804B-305A-8FCE-5F06821B544C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff50758000 - 0x7fff5090eff5 com.apple.CoreUtils (6.2.1 - 621.5) <CD4B58E5-1494-3457-84FF-3869378E2DC9> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff50a48000 - 0x7fff50a5bff1 com.apple.CrashReporterSupport (10.13 - 15016) <827F4E31-9F23-3683-AC5A-59CCA90F2359> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff50b14000 - 0x7fff50b26ff8 com.apple.framework.DFRFoundation (1.0 - 252.50.1) <19F79D32-71D3-3A87-98C9-B5C6C96076C4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff50b27000 - 0x7fff50b2cfff com.apple.DSExternalDisplay (3.1 - 380) <971F24F1-B1FC-3674-9C00-F88EEF94DC05> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff50bb6000 - 0x7fff50c30ff0 com.apple.datadetectorscore (8.0 - 659) <9FD9BDFA-3724-3BEA-946C-0473447196A3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff50c32000 - 0x7fff50c7bffe com.apple.DataDetectorsNaturalLanguage (1.0 - 154) <49A864A2-386D-3B90-8371-ABB1E3EBE769> /System/Library/PrivateFrameworks/DataDetectorsNaturalLanguage.framework/Versions/A/DataDetectorsNaturalLanguage
0x7fff50c7c000 - 0x7fff50cb9ff8 com.apple.DebugSymbols (194 - 194) <9BCE6685-6C45-3DF9-98EB-FCF8196160F0> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff50cba000 - 0x7fff50e42ff6 com.apple.desktopservices (1.14.5 - 1281.5.3) <79972B8B-7B60-3AD5-9A5F-17976DE8080B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff50e58000 - 0x7fff50e64ff8 com.apple.DeviceIdentity (1.0 - 1) <6E017199-DFC0-3464-A7E5-CB8928FC2F97> /System/Library/PrivateFrameworks/DeviceIdentity.framework/Versions/A/DeviceIdentity
0x7fff510df000 - 0x7fff511a7ffe com.apple.DiskImagesFramework (559.100.2 - 559.100.2) <DE281E96-21D0-3BE3-BEE0-D901B24D71EE> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff511a8000 - 0x7fff5127bff1 com.apple.DiskManagement (13.0 - 1648.120.5) <650DBBE4-6624-3064-A26D-6BCAA0FE41F9> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff5127c000 - 0x7fff51280ff1 com.apple.DisplayServicesFW (3.1 - 380) <A5F74849-D8E4-30DC-A638-BFD4332CD6AB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff512da000 - 0x7fff512feff9 com.apple.DuetActivityScheduler (1.0 - 1) <C63FCC5A-CF9B-31B0-B549-04FC4527B826> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
0x7fff51328000 - 0x7fff5135dff7 com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <E0BAD6DA-3F7C-32A4-AB32-13C9D604690B> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
0x7fff5135e000 - 0x7fff51362ff9 com.apple.EFILogin (2.0 - 2) <B95015BC-5BC2-33D9-AD94-01905DD56193> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff51e77000 - 0x7fff51e94ffd com.apple.EmojiFoundation (1.0 - 1) <F9DDF38F-6F80-3706-8981-DE306A910607> /System/Library/PrivateFrameworks/EmojiFoundation.framework/Versions/A/EmojiFoundation
0x7fff51e95000 - 0x7fff51eaaff2 com.apple.Engram (1.0 - 1) <15ABEF9F-1892-3801-9253-0FD0FC232B1C> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
0x7fff51eab000 - 0x7fff52515ff9 com.apple.vision.EspressoFramework (1.0 - 188.4) <4502588F-70F2-3A5F-9089-4B2F29159961> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
0x7fff5255e000 - 0x7fff525bbff2 com.apple.ExchangeWebServices (8.0 - 807) <4D4106E5-50B0-3DC5-99DF-A236829D791A> /System/Library/PrivateFrameworks/ExchangeWebServices.framework/Versions/A/ExchangeWebServices
0x7fff527f0000 - 0x7fff52c0bff1 com.apple.vision.FaceCore (4.3.0 - 4.3.0) <1B5D7DD6-718E-3111-A702-EB04B8903662> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff532a9000 - 0x7fff533e1ffc libFontParser.dylib (277.2.5.3) <DEB18756-082F-359B-AE93-F9C3B5EC7AF4> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff533e2000 - 0x7fff53416fff libTrueTypeScaler.dylib (277.2.5.3) <B16255A6-C51A-328B-B679-8FBF64495770> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff5347b000 - 0x7fff5348bff6 libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <6396BC1F-13C1-37D7-91B9-1FF60910C7FA> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff5696c000 - 0x7fff5696dfff libmetal_timestamp.dylib (902.14.11) <BE88F259-0A3C-3910-8983-FB5E2C905E87> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff5802a000 - 0x7fff58030fff com.apple.GPUWrangler (5.2.4 - 5.2.4) <5B819701-9F0C-374B-8925-A22DFC16514F> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff5834f000 - 0x7fff58375ff1 com.apple.GenerationalStorage (2.0 - 314) <5613706F-710A-39E0-8B25-BA103A768613> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff5838e000 - 0x7fff59378ffc com.apple.GeoServices (1.0 - 1624.24.10.29.41) <9A6FF368-7127-336F-9595-B261141810EA> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff594a4000 - 0x7fff594b2ffb com.apple.GraphVisualizer (1.0 - 100.1) <0A86C9FF-4484-3C7F-BC71-3D23BDBE81CE> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff594b3000 - 0x7fff594c0ff3 com.apple.GraphicsServices (1.0 - 1.0) <628EA7EF-A5C7-36E4-9193-46F55852C208> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices
0x7fff5951b000 - 0x7fff59528ff9 com.apple.HID (1.0 - 1) <C750D8D3-C4DD-3E77-94B2-6A7B4D56DF2A> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
0x7fff59529000 - 0x7fff5952dffc com.apple.HIDAnalytics (1.0 - 1) <189D2197-30CA-3011-A14A-FEC7F02996B2> /System/Library/PrivateFrameworks/HIDAnalytics.framework/Versions/A/HIDAnalytics
0x7fff59651000 - 0x7fff5970fff4 com.apple.Heimdal (4.0 - 2.0) <F2C504F6-E211-3AB0-9754-D96D2F96634B> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff5a10c000 - 0x7fff5a13bff8 com.apple.HelpData (2.3 - 199) <31ECA355-3529-3FD8-961A-5E5F70DAE1A8> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff5aeab000 - 0x7fff5afa9ffe com.apple.ids (10.0 - 1000) <9CCCCDE9-74C2-313E-9933-A2AC43B59431> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
0x7fff5afaa000 - 0x7fff5b0e5ff2 com.apple.idsfoundation (10.0 - 1000) <C2830BDB-DAFF-34DF-8F26-1200AC9930A9> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
0x7fff5b703000 - 0x7fff5b763ff2 com.apple.imfoundation (10.0 - 1000) <47834C71-8DE3-35DF-BCD4-4D65A8524BEB> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x7fff5b889000 - 0x7fff5b892ffe com.apple.IOAccelMemoryInfo (1.0 - 1) <903349F6-F3B0-3269-8946-2CE3E2C49E70> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff5b893000 - 0x7fff5b89bff5 com.apple.IOAccelerator (438.5.4 - 438.5.4) <A3CF45E0-4D88-33BF-BAEC-690D5664CDA0> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5b8a8000 - 0x7fff5b8bffff com.apple.IOPresentment (1.0 - 37) <3EDBB454-D248-394B-A026-9717CD8535C3> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5bc47000 - 0x7fff5bc92ff1 com.apple.IconServices (438.3 - 438.3) <2AE74790-64F1-3B0A-9534-DEEEE307E562> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff5be2f000 - 0x7fff5be3dfff com.apple.IntentsFoundation (1.0 - 1) <C2C31BEB-FFCE-31E1-BA23-A093693C0BDC> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
0x7fff5be50000 - 0x7fff5be57ff9 com.apple.InternationalSupport (1.0 - 45.4) <C22AA77A-EDA6-3626-8816-521A8CD43C4A> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff5be58000 - 0x7fff5be5aff3 com.apple.InternationalTextSearch (1.0 - 1) <46B97E2B-B50E-37FE-9476-FD30BDAA3ED5> /System/Library/PrivateFrameworks/InternationalTextSearch.framework/Versions/A/InternationalTextSearch
0x7fff5bebf000 - 0x7fff5beeeff3 com.apple.IntlPreferences (2.0 - 301.6) <FCA47550-A8C7-3A53-A1EE-1D26519B4C60> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff5c0d7000 - 0x7fff5c0e3ff7 com.apple.KerberosHelper (4.0 - 1.0) <C65553B0-AB50-31AB-A192-B6DC53A3962C> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
0x7fff5c0e4000 - 0x7fff5c103ffd com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <76DB5326-BE5D-3339-975C-D9FCF39A341E> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff5c238000 - 0x7fff5c306ffd com.apple.LanguageModeling (1.0 - 215.1) <A6FAA215-9A01-3EE1-B304-2238801C5883> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5c307000 - 0x7fff5c34ffff com.apple.Lexicon-framework (1.0 - 72) <6AE1872C-0352-36FE-90CC-7303F13A5BEF> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff5c356000 - 0x7fff5c35bff3 com.apple.LinguisticData (1.0 - 353.18) <686E7B7C-640F-3D7B-A9C1-31E2DFACD457> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff5c382000 - 0x7fff5c3a6ffe com.apple.locationsupport (2394.0.22 - 2394.0.22) <5C15E3FF-D269-3A99-B3EF-B806F61EE1EA> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
0x7fff5c3ff000 - 0x7fff5c404ff7 com.apple.LoginUICore (4.0 - 4.0) <5D60C7D1-9DB7-30A3-9209-7E13644D3E9D> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff5c779000 - 0x7fff5c77bffe com.apple.framework.machinesettings (11.0 - 11.0) <4FD3F225-97BB-3E93-B976-ED932D7A5DE5> /System/Library/PrivateFrameworks/MachineSettings.framework/Versions/A/MachineSettings
0x7fff5cbf3000 - 0x7fff5cbf6fff com.apple.Mangrove (1.0 - 25) <11A30F47-B1C1-375E-9FE7-0A196E92A52C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff5cdb3000 - 0x7fff5cdb3ff5 com.apple.marco (10.0 - 1000) <DE306413-2B75-3D3A-9DCC-0D660A3197CB> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x7fff5cdb4000 - 0x7fff5cddaffc com.apple.MarkupUI (1.0 - 325.9) <FB688EC0-67FD-37A2-BED0-A017F4FA029A> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
0x7fff5ce5f000 - 0x7fff5cee9ff8 com.apple.MediaExperience (1.0 - 1) <34E15DA2-02AA-32FA-99E1-9A139521E226> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff5ceea000 - 0x7fff5cf1dfff com.apple.MediaKit (16 - 923) <14E38848-C9BD-37F1-AE44-FC4CC839E8A1> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff5cfe2000 - 0x7fff5d377ff9 com.apple.MediaRemote (1.0 - 1) <CEA58C03-7579-31CC-98E3-6820AD238F53> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
0x7fff5d378000 - 0x7fff5d3b4ffc com.apple.MediaServices (1.0 - 1) <B2385109-3D9F-3F86-BAAF-CB8F53118B9D> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
0x7fff5d6c2000 - 0x7fff5d70efff com.apple.spotlight.metadata.utilities (1.0 - 2076.6) <C3AEA22D-1FEB-3E38-9821-1FA447C8AF9D> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff5d70f000 - 0x7fff5d7e0ffa com.apple.gpusw.MetalTools (1.0 - 1) <A23FFAB6-437C-303C-A3E8-99F323F8E734> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff5d83e000 - 0x7fff5d857ff4 com.apple.MobileAssets (1.0 - 619.120.1) <5AF95641-68C7-351A-A317-3C7B793502D6> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff5da14000 - 0x7fff5da32fff com.apple.MobileKeyBag (2.0 - 1.0) <B564179F-A5E9-3BD8-892D-CEF2BE0DA0D7> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff5dafe000 - 0x7fff5dc94ffd com.apple.Montreal (1.0 - 121.1) <9A9642A5-CE1F-3C1E-ACEF-C3CC789A1D26> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
0x7fff5dc95000 - 0x7fff5dcc5ff7 com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <4E7CB188-382E-3128-8671-4A3EF6E06622> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff5df45000 - 0x7fff5e02fffe com.apple.NLP (1.0 - 202) <C07578AE-5E92-3F8C-943A-7661B51A7EB8> /System/Library/PrivateFrameworks/NLP.framework/Versions/A/NLP
0x7fff5e1c5000 - 0x7fff5e1cffff com.apple.NetAuth (6.2 - 6.2) <D660F2CB-5A49-3DD0-9DB3-86EF0797828C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff5e93c000 - 0x7fff5e93effe com.apple.OAuth (25 - 25) <71C237D9-27B1-333D-AA57-3E3E2DAB2020> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
0x7fff5ebe5000 - 0x7fff5ec30ffb com.apple.OTSVG (1.0 - 643.1.5.1) <CD494F00-9AA4-3A48-916B-EA8661F9772D> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff5fe44000 - 0x7fff5fe4fff2 com.apple.PerformanceAnalysis (1.243.2 - 243.2) <941698D6-EF00-3D59-8560-F160BC04B412> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff5fe50000 - 0x7fff5fe78ffb com.apple.persistentconnection (1.0 - 1.0) <FFC20BB6-9CF3-39F2-AE5C-8DEE348FE0C1> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff5fe79000 - 0x7fff5fe87ffe com.apple.PersonaKit (1.0 - 1) <C2FEE024-D4D9-3E2F-89A9-3F054E7A28BA> /System/Library/PrivateFrameworks/PersonaKit.framework/Versions/A/PersonaKit
0x7fff60031000 - 0x7fff60031ffa com.apple.PhoneNumbers (1.0 - 1) <08BB706C-0D00-3519-B038-0770DE877865> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff618f1000 - 0x7fff61921ff7 com.apple.pluginkit.framework (1.0 - 1) <6A417FEF-CEDE-3EE0-93ED-42680A31C886> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff6194c000 - 0x7fff6195fffc com.apple.PowerLog (1.0 - 1) <63A89A9B-2ACC-3378-9BD0-7FA971E07C2A> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff61c15000 - 0x7fff61c40ffe com.apple.frameworks.preferencepanessupport (13.0 - 13.0) <4E2844A5-04BD-36FC-B59D-1F63590B5C83> /System/Library/PrivateFrameworks/PreferencePanesSupport.framework/Versions/A/PreferencePanesSupport
0x7fff625e5000 - 0x7fff62605ff1 com.apple.proactive.support.ProactiveEventTracker (1.0 - 258.5) <49DE6D83-AC45-327B-BC2B-B08DD14CA92E> /System/Library/PrivateFrameworks/ProactiveEventTracker.framework/Versions/A/ProactiveEventTracker
0x7fff6268c000 - 0x7fff626f5ff2 com.apple.proactive.support.ProactiveSupport (1.0 - 258.5) <95F0086C-329D-3255-91FF-908EB1BABD28> /System/Library/PrivateFrameworks/ProactiveSupport.framework/Versions/A/ProactiveSupport
0x7fff627db000 - 0x7fff62835ff6 com.apple.ProtectedCloudStorage (1.0 - 1) <969BF7A2-E989-3A22-BC1B-72B72E107229> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff62836000 - 0x7fff6284fffb com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <A2E34123-7CED-378B-A43D-1B98B5B85F5C> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff62961000 - 0x7fff62964ff4 com.apple.QuickLookNonBaseSystem (1.0 - 1) <4579D418-9C34-3F29-B121-0046F2B87D0B> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
0x7fff62965000 - 0x7fff62988ff0 com.apple.quicklook.QuickLookSupport (1.0 - 1) <D4E71FA6-5776-304F-B007-51FFC81C6780> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
0x7fff629cf000 - 0x7fff62a48ff3 com.apple.Rapport (1.9.5 - 195.2) <6DB4EFB5-A70C-36AA-971B-3B728EEF41AB> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
0x7fff62c8f000 - 0x7fff62c9bff5 com.apple.xpc.RemoteServiceDiscovery (1.0 - 1738.120.8) <9754FC8C-3EAF-3F9B-8A28-A63D472DD6F0> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff62cae000 - 0x7fff62cd7ff1 com.apple.RemoteViewServices (2.0 - 148) <1C61CFC2-F76F-31E5-BA13-EFD5DC69C8D5> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff62cd8000 - 0x7fff62cedffa com.apple.xpc.RemoteXPC (1.0 - 1738.120.8) <BEC43C3B-D472-335D-8D4B-90DCACEC5758> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff62d5b000 - 0x7fff62da5ffa com.apple.ResponseKit (1.0 - 148.2) <4A0541D5-0642-3D35-B6EF-AC613CCFE098> /System/Library/PrivateFrameworks/ResponseKit.framework/Versions/A/ResponseKit
0x7fff62e3c000 - 0x7fff62e77ff0 com.apple.RunningBoardServices (1.0 - 223.100.31) <9FD1FC53-186A-3327-A359-B0BC7F4360EF> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff63b9f000 - 0x7fff63bebff9 com.apple.Safari.SafeBrowsing (15609 - 15609.2.9.1.2) <57AC0345-D349-3477-9ECA-9BAD465819EA> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
0x7fff64757000 - 0x7fff6475aff5 com.apple.SecCodeWrapper (4.0 - 448.100.6) <813B3E57-6A95-3D7B-9094-C65D687A72B8> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff648cd000 - 0x7fff649f4ff0 com.apple.Sharing (1526.31 - 1526.31) <2CB07F08-7794-3BF2-9ED5-BAB5C55C9D2C> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff64a4d000 - 0x7fff64a6bff2 com.apple.shortcut (2.16 - 106) <51323823-C5EB-3EE0-AA81-8D633A3F75BD> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff64a6c000 - 0x7fff64a8cff5 com.apple.sidecar-core (1.0 - 209.40.4) <A5BEBCF6-0B2F-3BA7-9F4C-A65E4AECB2E6> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
0x7fff64a8d000 - 0x7fff64a9fff0 com.apple.sidecar-ui (1.0 - 209.40.4) <55486B3A-B65A-3023-89C7-A154A39D0D7E> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
0x7fff65e07000 - 0x7fff660fdff7 com.apple.SkyLight (1.600.0 - 451.4) <F5B9065A-E975-36D1-8D53-9FBF02171FAB> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff6694a000 - 0x7fff66958ffb com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <820602AB-117B-3C3E-B20B-819CBC97B7A4> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff66a1a000 - 0x7fff66ca4ffe com.apple.spotlight.index (10.7.0 - 2076.6) <38E208FE-A4E5-3B6C-9937-97CA152F1BB2> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff67032000 - 0x7fff67073ff9 com.apple.StreamingZip (1.0 - 1) <EFCDDC94-28EE-3BCA-A105-0A928D15ED8C> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff6718a000 - 0x7fff67193ff7 com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.1) <581F31D6-94CB-38AA-BD56-1A63606E516E> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff67204000 - 0x7fff6722effa com.apple.framework.SystemAdministration (1.0 - 1.0) <926BB2F5-E02C-30B7-949A-20EFE57CF242> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff6744a000 - 0x7fff6745aff3 com.apple.TCC (1.0 - 1) <FD146B21-6DC0-3B66-BB95-57A5016B1365> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff6797f000 - 0x7fff67a45ff0 com.apple.TextureIO (3.10.9 - 3.10.9) <E23E05ED-8190-3564-985E-446F15CB0709> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff67bd1000 - 0x7fff67bd2fff com.apple.TrustEvaluationAgent (2.0 - 33) <11DF5A28-4410-36A8-B3B8-BF1094BE1544> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff67c0a000 - 0x7fff67e62ff0 com.apple.UIFoundation (1.0 - 662) <DFD3DD4A-E661-3A12-BB02-06898949617D> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff67ef9000 - 0x7fff67effffe com.apple.URLFormatting (119 - 119.18) <CE5B7B2B-7CB9-3214-BFA2-D6D4F13D7652> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff689f5000 - 0x7fff68a0eff4 com.apple.UniversalAccessCore (7.0 - 487.14) <3EE24AB0-6CC7-34FC-AFCB-40A171E14E7C> /System/Library/PrivateFrameworks/UniversalAccess.framework/Versions/A/Frameworks/UniversalAccessCore.framework/Versions/A/UniversalAccessCore
0x7fff68a42000 - 0x7fff68a44fff libUAPreferences.dylib (487.14) <FF8A89EA-7E6F-30D5-B68C-0DCA81C34301> /System/Library/PrivateFrameworks/UniversalAccess.framework/Versions/A/Libraries/libUAPreferences.dylib
0x7fff68a45000 - 0x7fff68a4aff9 com.apple.UniversalAccess (7.0 - 487.14) <4AE93E83-DD67-31FD-B589-A0500B57F993> /System/Library/PrivateFrameworks/UniversalAccess.framework/Versions/A/UniversalAccess
0x7fff68ad5000 - 0x7fff68af5ffc com.apple.UserManagement (1.0 - 1) <E168206A-9DC1-3C67-A9A6-52D816DBD5B1> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff698a1000 - 0x7fff6998bff8 com.apple.ViewBridge (464.1 - 464.1) <C698BAC9-26C8-39F1-BBC0-F57EBD2EFD7B> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff69b31000 - 0x7fff69b32fff com.apple.WatchdogClient.framework (1.0 - 67.120.2) <3B8EBB6B-77D0-317C-A3DB-D0D2E294B18D> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff69d05000 - 0x7fff69d05fff com.apple.WebInspectorUI (15609 - 15609.2.9.1.2) <7BDB4287-9F2D-399E-9850-F6F9CDAC5D33> /System/Library/PrivateFrameworks/WebInspectorUI.framework/Versions/A/WebInspectorUI
0x7fff69ebe000 - 0x7fff69ef9fff libAWDSupport.dylib (949) <C4E783A8-A8D8-307D-AD50-3B66A8944B8E> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupport.dylib
0x7fff69efa000 - 0x7fff6a1daff7 libAWDSupportFramework.dylib (3541.1) <1F4FB417-EE92-3095-9940-C35C93F6F020> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
0x7fff6a1db000 - 0x7fff6a1ecfff libprotobuf-lite.dylib (3541.1) <3EB3CBE0-544B-38D1-81EB-7D73CA221967> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
0x7fff6a1ed000 - 0x7fff6a246ffb libprotobuf.dylib (3541.1) <45F77AE5-5D7A-30E7-9168-5546FDC59CA2> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
0x7fff6a247000 - 0x7fff6a28bff6 com.apple.awd (1.0 - 949) <DAF51750-FD03-3509-9CBB-83E9EF0FB363> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
0x7fff6a75f000 - 0x7fff6a762ffa com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <D4F09EC7-C63F-3861-B5DA-3F7C0DFF153D> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff6a76a000 - 0x7fff6a7c8ff0 com.apple.xquery (1.3.1 - 30) <C43B5F76-7048-3EE7-8875-621E0FC7F100> /System/Library/PrivateFrameworks/XQuery.framework/Versions/A/XQuery
0x7fff6a7c9000 - 0x7fff6a7ccff0 com.apple.private.XprotectFrameWork.XprotectFramework (1.0 - 1) <2D617702-4243-3C10-8251-49E850B69D31> /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XprotectFramework
0x7fff6a7dc000 - 0x7fff6a7eaff5 com.apple.audio.caulk (1.0 - 32.3) <7D3D2F91-8B1D-3558-B324-45BDF11306DB> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff6a9b2000 - 0x7fff6a9e7ffe com.apple.iCalendar (7.0 - 810.4.1) <883A965D-DB8B-3038-89E5-0C76D1D67206> /System/Library/PrivateFrameworks/iCalendar.framework/Versions/A/iCalendar
0x7fff6ab2c000 - 0x7fff6ab2eff3 com.apple.loginsupport (1.0 - 1) <31F02734-1ECF-37D9-9DF6-7C3BC3A324FE> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff6ab2f000 - 0x7fff6ab42ffd com.apple.login (3.0 - 3.0) <1DC570FD-29EC-3AE8-BD34-D44C00E4621B> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff6ab74000 - 0x7fff6ab80ffd com.apple.perfdata (1.0 - 51.100.6) <2F2B9D0F-CB87-3712-B04B-DA075A48002B> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
0x7fff6ab81000 - 0x7fff6abb2ffd com.apple.contacts.vCard (1.0 - 3455.18) <A21D2C58-54FB-34DD-B6B3-6A95A1178D27> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff6d520000 - 0x7fff6d535ffe libAccessibility.dylib (2790.70) <0175DCAB-ADCB-3F8F-BD64-E8E51C00825E> /usr/lib/libAccessibility.dylib
0x7fff6d605000 - 0x7fff6d611ff9 libAudioStatistics.dylib (1104.84) <CBFD7F79-15F1-3828-B2FF-921F71C91FDC> /usr/lib/libAudioStatistics.dylib
0x7fff6d612000 - 0x7fff6d645ffa libAudioToolboxUtility.dylib (1104.84) <BB234563-F952-3E7F-B630-4140DB5E0380> /usr/lib/libAudioToolboxUtility.dylib
0x7fff6d64c000 - 0x7fff6d680fff libCRFSuite.dylib (48) <02C52318-C537-3FD8-BBC4-E5BD25430652> /usr/lib/libCRFSuite.dylib
0x7fff6d683000 - 0x7fff6d68dfff libChineseTokenizer.dylib (34) <04A7CB5A-FD68-398A-A206-33A510C115E7> /usr/lib/libChineseTokenizer.dylib
0x7fff6d68e000 - 0x7fff6d716fff libCoreStorage.dylib (551) <BBD3B3DC-270D-35F2-8C67-4595A257EEBB> /usr/lib/libCoreStorage.dylib
0x7fff6d719000 - 0x7fff6d71bff7 libDiagnosticMessagesClient.dylib (112) <27220E98-6CE2-33E3-BD48-3CC3CE4AA036> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff6d761000 - 0x7fff6d918ffb libFosl_dynamic.dylib (100.4) <68038226-8CAA-36B5-B5D6-510F900B318D> /usr/lib/libFosl_dynamic.dylib
0x7fff6d93f000 - 0x7fff6d945ff3 libIOReport.dylib (54) <E3A2148E-C5B2-30A8-ACD3-E081DD02BE90> /usr/lib/libIOReport.dylib
0x7fff6da27000 - 0x7fff6da2efff libMatch.1.dylib (36) <081FB6A9-0482-3697-A98B-6821FF476C6E> /usr/lib/libMatch.1.dylib
0x7fff6da5d000 - 0x7fff6da7dfff libMobileGestalt.dylib (826.120.5) <1977AD00-533A-31AA-8D74-EA6CB962F668> /usr/lib/libMobileGestalt.dylib
0x7fff6dafd000 - 0x7fff6dbdaff7 libSMC.dylib (20) <5FCE668E-C4D5-3E36-98B9-6DF720DCD886> /usr/lib/libSMC.dylib
0x7fff6dbdb000 - 0x7fff6dbdfffb libScreenReader.dylib (708.13) <FC5AFA8B-1BFE-3DA7-A3C7-58B36C72321B> /usr/lib/libScreenReader.dylib
0x7fff6dbef000 - 0x7fff6dbf0fff libSystem.B.dylib (1281.100.1) <B6FDA8A9-3D2B-3BD5-B5B0-57D311C0FF3D> /usr/lib/libSystem.B.dylib
0x7fff6dbf1000 - 0x7fff6dc7cff7 libTelephonyUtilDynamic.dylib (5017.1) <4C11A09D-9B7E-3743-B9E6-39B4D466BAF1> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff6dc7d000 - 0x7fff6dc7efff libThaiTokenizer.dylib (3) <97DC10ED-3C11-3C89-B366-299A644035E7> /usr/lib/libThaiTokenizer.dylib
0x7fff6dc7f000 - 0x7fff6dc85ff9 libUniversalAccess.dylib (487.14) <0AB6B41F-610E-3605-A949-92C7A88CA1F5> /usr/lib/libUniversalAccess.dylib
0x7fff6dc96000 - 0x7fff6dcacfff libapple_nghttp2.dylib (1.39.2) <B99D7150-D4E2-31A2-A594-36DA4B90D558> /usr/lib/libapple_nghttp2.dylib
0x7fff6dce1000 - 0x7fff6dd53ff7 libarchive.2.dylib (72.100.1) <20B70252-0C4B-3AFD-8C8D-F51921E9D324> /usr/lib/libarchive.2.dylib
0x7fff6dd54000 - 0x7fff6ddedfe5 libate.dylib (3.0.1) <C4A5AE88-4E44-36FA-AD3E-0629AF9B94E0> /usr/lib/libate.dylib
0x7fff6ddf1000 - 0x7fff6ddf1ff3 libauto.dylib (187) <85383E24-1592-36BC-BB39-308B7F1C826E> /usr/lib/libauto.dylib
0x7fff6ddf2000 - 0x7fff6deb6ffe libboringssl.dylib (283.120.1) <96F48388-EEC8-3034-8E8A-8D37DD0E49D9> /usr/lib/libboringssl.dylib
0x7fff6deb7000 - 0x7fff6dec7ffb libbsm.0.dylib (60.100.1) <B2331E11-3CBB-3BCF-93A6-12627AE444D0> /usr/lib/libbsm.0.dylib
0x7fff6dec8000 - 0x7fff6ded4fff libbz2.1.0.dylib (44) <BF40E193-8856-39B7-98F8-7A17B328B1E9> /usr/lib/libbz2.1.0.dylib
0x7fff6ded5000 - 0x7fff6df27fff libc++.1.dylib (902.1) <AD0805FE-F98B-3E2F-B072-83782B22DAC9> /usr/lib/libc++.1.dylib
0x7fff6df28000 - 0x7fff6df3dffb libc++abi.dylib (902) <771E9263-E832-3985-9477-8F1B2D73B771> /usr/lib/libc++abi.dylib
0x7fff6df3e000 - 0x7fff6df3efff libcharset.1.dylib (59) <FF23D4ED-A5AD-3592-9574-48486C7DF85B> /usr/lib/libcharset.1.dylib
0x7fff6df3f000 - 0x7fff6df50fff libcmph.dylib (8) <296A51E6-9661-3AC2-A1C9-F1E3510F91AA> /usr/lib/libcmph.dylib
0x7fff6df51000 - 0x7fff6df68fd7 libcompression.dylib (87) <21F37C2E-B9AA-38CE-9023-B763C8828AC6> /usr/lib/libcompression.dylib
0x7fff6e242000 - 0x7fff6e258ff7 libcoretls.dylib (167) <9E5D1E0C-03F8-37B6-82A1-0D0597021CB8> /usr/lib/libcoretls.dylib
0x7fff6e259000 - 0x7fff6e25afff libcoretls_cfhelpers.dylib (167) <C23BE09B-85D1-3744-9E7B-E2B11ACD5442> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff6e6fd000 - 0x7fff6e801fef libcrypto.44.dylib (47.120.1) <B48C0D1A-CDCB-34E4-921E-00EBFF1208DE> /usr/lib/libcrypto.44.dylib
0x7fff6e804000 - 0x7fff6e80ffff libcsfde.dylib (551) <8FBB94EC-712C-3C0F-A8A9-88EE5F4679EF> /usr/lib/libcsfde.dylib
0x7fff6e817000 - 0x7fff6e876ff7 libcups.2.dylib (483.6) <FFE8FE67-A6CC-3C38-A9D7-D411D7B562F1> /usr/lib/libcups.2.dylib
0x7fff6e878000 - 0x7fff6e8ddff7 libcurl.4.dylib (118.120.2) <F2C246F3-460E-31A7-B900-2A9560533730> /usr/lib/libcurl.4.dylib
0x7fff6e980000 - 0x7fff6e980fff libenergytrace.dylib (21) <DBF8BDEE-7229-3F06-AC10-A28DCC4243C0> /usr/lib/libenergytrace.dylib
0x7fff6e981000 - 0x7fff6e999fff libexpat.1.dylib (19.60.2) <C9163264-BA81-3CC6-9B8C-48A9A0709DD5> /usr/lib/libexpat.1.dylib
0x7fff6e99a000 - 0x7fff6e9a6ffb libexslt.0.dylib (16.9) <AC76264B-F716-3479-AAEF-FCF6F1AC0FE8> /usr/lib/libexslt.0.dylib
0x7fff6e9a7000 - 0x7fff6e9a9fff libfakelink.dylib (149.1) <122F530F-F10E-3DD5-BBEA-91796BE583F3> /usr/lib/libfakelink.dylib
0x7fff6e9aa000 - 0x7fff6e9aff57 libffi.dylib (26) <7EF62CB6-6AD5-33E1-AFC3-35002BBE24C0> /usr/lib/libffi.dylib
0x7fff6e9b8000 - 0x7fff6e9bdfff libgermantok.dylib (24) <DD279BF6-E906-30D3-A69E-DC797E95F147> /usr/lib/libgermantok.dylib
0x7fff6e9be000 - 0x7fff6e9c7ff7 libheimdal-asn1.dylib (564.100.1) <68FA1BE5-8FFC-3345-8980-8D8629EBA451> /usr/lib/libheimdal-asn1.dylib
0x7fff6e9c8000 - 0x7fff6eab8fff libiconv.2.dylib (59) <F58FED71-6CCA-30E8-9A51-13E9B46E568D> /usr/lib/libiconv.2.dylib
0x7fff6eab9000 - 0x7fff6ed10fff libicucore.A.dylib (64260.0.1) <7B9204AC-EA14-3FF3-B6B9-4C85B37EED79> /usr/lib/libicucore.A.dylib
0x7fff6ed2a000 - 0x7fff6ed2bfff liblangid.dylib (133) <36581D30-1C7B-3A58-AA07-36237BD75E0E> /usr/lib/liblangid.dylib
0x7fff6ed2c000 - 0x7fff6ed44ff3 liblzma.5.dylib (16) <4DB30730-DBD1-3503-957A-D604049B98F9> /usr/lib/liblzma.5.dylib
0x7fff6ed5c000 - 0x7fff6ee03ff7 libmecab.dylib (883.11) <66AD729B-2BCC-3347-B9B3-FD88570E884D> /usr/lib/libmecab.dylib
0x7fff6ee04000 - 0x7fff6f066ff1 libmecabra.dylib (883.11) <2AE744D2-AC95-3720-8E66-4F9C7A79384C> /usr/lib/libmecabra.dylib
0x7fff6f3d3000 - 0x7fff6f402fff libncurses.5.4.dylib (57) <B0B09D08-A7C9-38E9-8BF4-E4F4882F93A6> /usr/lib/libncurses.5.4.dylib
0x7fff6f532000 - 0x7fff6f9aeff5 libnetwork.dylib (1880.120.4) <715FB943-BA01-351C-BEA6-121970472985> /usr/lib/libnetwork.dylib
0x7fff6f9af000 - 0x7fff6f9c6fff libnetworkextension.dylib (1095.120.6) <782E43F6-1FB9-3A5F-AF24-AC21A63C1A37> /usr/lib/libnetworkextension.dylib
0x7fff6fa4f000 - 0x7fff6fa82fde libobjc.A.dylib (787.1) <CA836D3E-4595-33F1-B70C-7E39A3FBBE16> /usr/lib/libobjc.A.dylib
0x7fff6fa83000 - 0x7fff6fa84ff7 libodfde.dylib (26) <2DDA61BF-E92A-3463-B1C4-D59E40D34D34> /usr/lib/libodfde.dylib
0x7fff6fa95000 - 0x7fff6fa99fff libpam.2.dylib (25.100.1) <732E8D8E-C630-3EC2-B6C3-A1564E3B68B8> /usr/lib/libpam.2.dylib
0x7fff6fa9c000 - 0x7fff6fad2ff7 libpcap.A.dylib (89.120.1) <CF2ADF15-2D44-3A35-94B4-DD24052F9B23> /usr/lib/libpcap.A.dylib
0x7fff6fad3000 - 0x7fff6fb10fff libpcre.0.dylib (11) <984E832C-91F9-3126-A750-CBE6BB9573A3> /usr/lib/libpcre.0.dylib
0x7fff6fb12000 - 0x7fff6fb20ff9 libperfcheck.dylib (37.100.2) <4B1B7D59-2A8B-3E32-AAE6-B428252A5204> /usr/lib/libperfcheck.dylib
0x7fff6fb56000 - 0x7fff6fb6efff libresolv.9.dylib (67.40.1) <B0F5D204-7EF2-3B0B-90EF-BB4D196FCC62> /usr/lib/libresolv.9.dylib
0x7fff6fb70000 - 0x7fff6fbb4ff7 libsandbox.1.dylib (1217.120.7) <728BC15F-9A6C-3634-9427-60C01CB5A5D6> /usr/lib/libsandbox.1.dylib
0x7fff6fbb5000 - 0x7fff6fbc7ff7 libsasl2.2.dylib (213.120.1) <E6375405-168D-3B75-8042-C8B329D01AB9> /usr/lib/libsasl2.2.dylib
0x7fff6fbc8000 - 0x7fff6fbc9ff7 libspindump.dylib (281.3) <0C3A8B48-DC31-3F61-B4CC-746157042D0E> /usr/lib/libspindump.dylib
0x7fff6fbca000 - 0x7fff6fdb4ff7 libsqlite3.dylib (308.5) <AF518115-4AD1-39F2-9B82-E2640E2221E1> /usr/lib/libsqlite3.dylib
0x7fff6fea8000 - 0x7fff6fed5ffb libssl.46.dylib (47.120.1) <6209494A-4AAD-344E-992C-03ACD2D4C402> /usr/lib/libssl.46.dylib
0x7fff6ff57000 - 0x7fff6ff88ff7 libtidy.A.dylib (17.1) <F4970713-89FD-360D-8670-5B46D8871BB8> /usr/lib/libtidy.A.dylib
0x7fff6ffaa000 - 0x7fff70004ff8 libusrtcp.dylib (1880.120.4) <E5B0C1C5-ADF2-37CF-8F2B-B196D2266474> /usr/lib/libusrtcp.dylib
0x7fff70005000 - 0x7fff70008ffb libutil.dylib (57) <D33B63D2-ADC2-38BD-B8F2-24056C41E07B> /usr/lib/libutil.dylib
0x7fff70009000 - 0x7fff70016ff7 libxar.1.dylib (425.2) <943A4CBB-331B-3A04-A11F-A2301189D40B> /usr/lib/libxar.1.dylib
0x7fff7001c000 - 0x7fff700feff7 libxml2.2.dylib (33.3) <262EF7C6-7D83-3C01-863F-36E97F5ACD34> /usr/lib/libxml2.2.dylib
0x7fff70102000 - 0x7fff7012afff libxslt.1.dylib (16.9) <86FE4382-BD77-3C19-A678-11EBCD70685A> /usr/lib/libxslt.1.dylib
0x7fff7012b000 - 0x7fff7013dff3 libz.1.dylib (76) <DB120508-3BED-37A8-B439-5235EAB4618A> /usr/lib/libz.1.dylib
0x7fff70167000 - 0x7fff70169ff9 liblog_network.dylib (1880.120.4) <517AFC4A-A772-37E9-B212-00398E23C2EE> /usr/lib/log/liblog_network.dylib
0x7fff709eb000 - 0x7fff709f0ff3 libcache.dylib (83) <A5ECC751-A681-30D8-B33C-D192C15D25C8> /usr/lib/system/libcache.dylib
0x7fff709f1000 - 0x7fff709fcfff libcommonCrypto.dylib (60165.120.1) <C321A74A-AA91-3785-BEBF-BEDC6975026C> /usr/lib/system/libcommonCrypto.dylib
0x7fff709fd000 - 0x7fff70a04fff libcompiler_rt.dylib (101.2) <652A6012-7E5C-3F4F-9438-86BC094526F3> /usr/lib/system/libcompiler_rt.dylib
0x7fff70a05000 - 0x7fff70a0eff7 libcopyfile.dylib (166.40.1) <40113A69-A81C-3397-ADC6-1D16B9A22C3E> /usr/lib/system/libcopyfile.dylib
0x7fff70a0f000 - 0x7fff70aa1fe3 libcorecrypto.dylib (866.120.3) <5E4B0E50-24DD-3E04-9374-EDA9FFD6257B> /usr/lib/system/libcorecrypto.dylib
0x7fff70bae000 - 0x7fff70beeff0 libdispatch.dylib (1173.100.2) <201EDBF3-0B36-31BA-A7CB-443CE35C05D4> /usr/lib/system/libdispatch.dylib
0x7fff70bef000 - 0x7fff70c25fff libdyld.dylib (750.5) <7E711A46-5E4D-393C-AEA6-440E2A5CCD0C> /usr/lib/system/libdyld.dylib
0x7fff70c26000 - 0x7fff70c26ffb libkeymgr.dylib (30) <52662CAA-DB1F-30A3-BE13-D6274B1A6D7B> /usr/lib/system/libkeymgr.dylib
0x7fff70c27000 - 0x7fff70c33ff3 libkxld.dylib (6153.121.2) <5EBB4886-C7B6-31D6-AA63-D861B2D58FCE> /usr/lib/system/libkxld.dylib
0x7fff70c34000 - 0x7fff70c34ff7 liblaunch.dylib (1738.120.8) <07CF647B-F9DC-3907-AD98-2F85FCB34A72> /usr/lib/system/liblaunch.dylib
0x7fff70c35000 - 0x7fff70c3aff7 libmacho.dylib (959.0.1) <D91DFF00-E22F-3796-8A1C-4C1F5F8FA03C> /usr/lib/system/libmacho.dylib
0x7fff70c3b000 - 0x7fff70c3dff3 libquarantine.dylib (110.40.3) <D3B7D02C-7646-3FB4-8529-B36DCC2419EA> /usr/lib/system/libquarantine.dylib
0x7fff70c3e000 - 0x7fff70c3fff7 libremovefile.dylib (48) <B5E88D9B-C2BE-3496-BBB2-C996317E18A3> /usr/lib/system/libremovefile.dylib
0x7fff70c40000 - 0x7fff70c57ff3 libsystem_asl.dylib (377.60.2) <1170348D-2491-33F1-AA79-E2A05B4A287C> /usr/lib/system/libsystem_asl.dylib
0x7fff70c58000 - 0x7fff70c58ff7 libsystem_blocks.dylib (74) <7AFBCAA6-81BE-36C3-8DB0-AAE0A4ACE4C5> /usr/lib/system/libsystem_blocks.dylib
0x7fff70c59000 - 0x7fff70ce0fff libsystem_c.dylib (1353.100.2) <935DDCE9-4ED0-3F79-A05A-A123DDE399CC> /usr/lib/system/libsystem_c.dylib
0x7fff70ce1000 - 0x7fff70ce4ffb libsystem_configuration.dylib (1061.120.2) <EA9BC2B1-5001-3463-9FAF-39FF61CAC87C> /usr/lib/system/libsystem_configuration.dylib
0x7fff70ce5000 - 0x7fff70ce8fff libsystem_coreservices.dylib (114) <3D0A3AA8-8415-37B2-AAE3-66C03BCE8B55> /usr/lib/system/libsystem_coreservices.dylib
0x7fff70ce9000 - 0x7fff70cf1fff libsystem_darwin.dylib (1353.100.2) <6EEC9975-EE3B-3C95-AA5B-030FD10587BC> /usr/lib/system/libsystem_darwin.dylib
0x7fff70cf2000 - 0x7fff70cf9fff libsystem_dnssd.dylib (1096.100.3) <0115092A-E61B-317D-8670-41C7C34B1A82> /usr/lib/system/libsystem_dnssd.dylib
0x7fff70cfa000 - 0x7fff70cfbffb libsystem_featureflags.dylib (17) <AFDB5095-0472-34AC-BA7E-497921BF030A> /usr/lib/system/libsystem_featureflags.dylib
0x7fff70cfc000 - 0x7fff70d49ff7 libsystem_info.dylib (538) <851693E9-C079-3547-AD41-353F8C248BE8> /usr/lib/system/libsystem_info.dylib
0x7fff70d4a000 - 0x7fff70d76ff7 libsystem_kernel.dylib (6153.121.2) <9F9902C9-A46F-3CA9-B7F9-5CCFE98FBF75> /usr/lib/system/libsystem_kernel.dylib
0x7fff70d77000 - 0x7fff70dbefff libsystem_m.dylib (3178) <436CFF76-6A99-36F2-A3B6-8D017396A050> /usr/lib/system/libsystem_m.dylib
0x7fff70dbf000 - 0x7fff70de6fff libsystem_malloc.dylib (283.100.6) <D4BA7DF2-57AC-33B0-B948-A688EE43C799> /usr/lib/system/libsystem_malloc.dylib
0x7fff70de7000 - 0x7fff70df4ffb libsystem_networkextension.dylib (1095.120.6) <6DE86DB0-8CD2-361E-BD6A-A34282B47847> /usr/lib/system/libsystem_networkextension.dylib
0x7fff70df5000 - 0x7fff70dfeff7 libsystem_notify.dylib (241.100.2) <7E9E2FC8-DF26-340C-B196-B81B11850C46> /usr/lib/system/libsystem_notify.dylib
0x7fff70dff000 - 0x7fff70e07fef libsystem_platform.dylib (220.100.1) <736920EA-6AE0-3B1B-BBDA-7DCDF0C229DF> /usr/lib/system/libsystem_platform.dylib
0x7fff70e08000 - 0x7fff70e12fff libsystem_pthread.dylib (416.100.3) <77488669-19A3-3993-AD65-CA5377E2475A> /usr/lib/system/libsystem_pthread.dylib
0x7fff70e13000 - 0x7fff70e17ff3 libsystem_sandbox.dylib (1217.120.7) <20C93D69-6452-3C82-9521-8AE54345C66F> /usr/lib/system/libsystem_sandbox.dylib
0x7fff70e18000 - 0x7fff70e1afff libsystem_secinit.dylib (62.100.2) <E851113D-D5B1-3FB0-9D29-9C7647A71961> /usr/lib/system/libsystem_secinit.dylib
0x7fff70e1b000 - 0x7fff70e22ffb libsystem_symptoms.dylib (1238.120.1) <25C3866B-004E-3621-9CD3-B1E9C4D887EB> /usr/lib/system/libsystem_symptoms.dylib
0x7fff70e23000 - 0x7fff70e39ff2 libsystem_trace.dylib (1147.120) <A1ED1D3A-5FAD-3559-A1D6-1BE4E1C5756A> /usr/lib/system/libsystem_trace.dylib
0x7fff70e3b000 - 0x7fff70e40ff7 libunwind.dylib (35.4) <253A12E2-F88F-3838-A666-C5306F833CB8> /usr/lib/system/libunwind.dylib
0x7fff70e41000 - 0x7fff70e76ffe libxpc.dylib (1738.120.8) <68D433B6-DCFF-385D-8620-F847FB7D4A5A> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 22
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 25677139
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=790.9M resident=0K(0%) swapped_out_or_unallocated=790.9M(100%)
Writable regions: Total=896.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=896.5M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 1664K 13
Activity Tracing 256K 1
CG image 2032K 45
CG raster data 8K 1
CoreAnimation 241.8M 637
CoreData Object IDs 4100K 2
CoreGraphics 8K 1
CoreImage 44K 5
CoreUI image data 5068K 43
Foundation 32K 2
Image IO 2176K 67
Kernel Alloc Once 48K 3
MALLOC 249.7M 114
MALLOC guard page 64K 15
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
Memory Tag 242 12K 1
Memory Tag 251 28K 2
SQLite page cache 832K 13
STACK GUARD 56.0M 9
Stack 12.1M 11
VM_ALLOCATE 120K 17
__DATA 54.5M 483
__DATA_CONST 53K 5
__FONT_DATA 4K 1
__LINKEDIT 402.4M 16
__OBJC_RO 32.2M 1
__OBJC_RW 1892K 2
__TEXT 388.5M 469
__UNICODE 564K 1
libnetwork 128K 8
mapped file 374.6M 124
shared memory 656K 18
TOTAL 2.2G 2131
TOTAL, minus reserved VM space 1.8G 2131
Model: MacBookPro14,3, BootROM 207.0.0.0.0, 4 processors, Quad-Core Intel Core i7, 2,9 GHz, 16 GB, SMC 2.45f4
Graphics: kHW_IntelHDGraphics630Item, Intel HD Graphics 630, spdisplays_builtin
Graphics: kHW_AMDRadeonPro560Item, Radeon Pro 560, spdisplays_pcie_device, 4 GB
Memory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x80CE, 0x4B3445424533303445422D45474347202020
Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x80CE, 0x4B3445424533303445422D45474347202020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x173), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1610.1)
Bluetooth: Version 7.0.5f6, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: External Disk 3.0
USB Device: USB 3.0 Bus
USB Device: motorola one vision
USB Device: Apple T1 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 41.4
I've installed last supplemental update of macOS and now, when I do two finger swipe, BTT crashes. Even without my profile active, only one action active, two fingers swipe.
I'm getting issues with BTT crashing with swipes as well.
shaferz
October 12, 2020, 5:10pm
#14
This appears to still be an issue unfortunately. Swipe actions are causing BTT to freeze up. Selecting the menubar icon, and selecting 'Restart BetterTouchtTool" brings it back until the next swiping.
BTT: 3.402
MacOS: 10.15.7
Using MacBook 16” 2020 and the issue is not present anymore. With that in mind I can confirm that it only occurs when using BTT on specific hardware.
shaferz
October 28, 2020, 10:00pm
#16
I gave up - just disabled the 2, 3 and 4 finger swipes and put in sliders instead. The locking up was happening far too frequently for me to try to ignore. :(. Maybe it'll be a fix in a future MacOS release.
shaferz
November 20, 2020, 8:05pm
#17
I did a completely fresh install of MacOS Big Sur the day after it was released. BTT was installed 6 days ago and my saved presets reimported. My swipe actions no longer trigger the original issue of the touchbar freezing with some swipe actions.
awesome, thanks for sharing!
