If you create a four finger gesture with certain combinations, the order will be incorrectly shown in the Trackpad Gesture column (in both the old and new configuration windows).
Specifically:
4, 1, 2, 3 shows as [2] [3] [4] [1]
3, 1, 2, 4 shows as [2] [3] [1] [4]
4, 1, 3, 2 shows as [2] [4] [3] [1]
The gestures still work as I inputted them (not as they are shown) The other combinations that I use are all displayed correctly.
Trackpad
- Type of Mac: MacBook Pro
- macOS version: 10.14.6
- BetterTouchTool version: 3.186 (1365)
