Describe the bug: Four finger double tap simply no longer works. Not sure how long it’s been broken for but it just refuses to work. Also, single four finger tap and four finger click refuse to work also. Four finger swipes work fine though. I’m not sure where I should start diagnosing what is going on here? Maybe a gesture conflict with other software?
Affected input device: Trackpad
N/A
Type of Mac: MPB 2023
macOS version: Tahoe 26.2
BetterTouchTool version: 6.154
So I have spent the last twenty minutes trying various things and I think I have unstuck it. From what I can tell, after making changes, ie: getting a different app to open or use a different gesture (after disabling others) wouldn’t work. However, if I restarted BTT after the change then it would stick.. and eventually it all started working as expected - but after each change, I needed to do a BTT restart, otherwise it wouldn’t work.
