Found a periodic power consumption anomaly
I found that when the synchronization function is enabled, there will be an abnormal power consumption anomaly every minute, which is manifested as the battery current and power increasing, and the main CPU temperature rising.
I would recommend to disable the experimental sync. It has some known issues and will be removed / replaced soon.
