Forum - light theme gone ?
Hallo @Andreas_Hegenberg,
Since today the forum light (default) theme is the same as the dark thene one…
Thx,
Christian
I did update the forum software today, however it still looks light to me. Maybe try a full refresh (opt+cmd+R) in case anything weird is cached
Weird, I checked accoss my iPhone,iPad and Mac (Safari/Chrome) all of them have a dark forum theme now. Refreshed/empty cache/logged out etc. Only when I change my systems theme to light I get the forum light (default) theme...
However my system theme I use normally for all systems is dark, but "before" I used somehow the light forum theme (default) across all platforms...with a dark system theme.
It is not the end of the world, but somehow weird...
Thx,
Christian
Ah true, the new forum version seem to auto-adapt to the system settings. There is probably a switch somewhere to disable that, I’ll check
You should now be able to select your preferred mode here:
Cool, thanks a lot !
Is it just me or on the light theme now it is quite hard to determine the unread topics:
For dark is better:
Hope there’s a way to change this.
Tried both Firefox and Safari - same colors.
Andreas, have you made some changes, now it is back to the old colors:
Yes, I did reset some things - should look better now!
