I am trying the Fn + Left Arrow Keyboard shortcut set to send Fn + Alt + Left Arrow
However, BTT is not recognizing the Fn key when trying to set it up.
It recognizes for the trigger but not for the shortcut action.
add a fn key down before your action and fn key up after the action ....it will work
I don’t think that is a valid shortcut in macOS, but you can try adding the predefined action „function key down“ before your shortcut and „function key up“ after your shortcut
Not sure whether that can work. In which app are you using that shortcut?
it does work ...I have many shortcuts made like this for fl studio.
Didn't work even after restarting BTT.
Maybe works with Shift Key for example, but not working for Fn key.
wait for a min ....lemme quickly check
I just instead used the "trigger menu bar item" action instead to achieve what I wanted to.
