Floating WebView shadow and border
Is there a way to have shadows and borders on floating webviews?
Best switch to the new Floating Menus. They will soon replace floating webviews (will happen automatically at some point). However they might not yet cover all functionality of the exsting floating webviews.
You can add a webview item to the floating menu, then it will behave very similar to the existing floating webviews:
One example is available here:
//edit: damn I broke the preset. One moment I'll reupload it
Thanks for the info, Andreas! Great work!
The link should now be working!
And best use the latest BTT alpha as I have just fixed an issue with rendering of borders.
The fix should be available with 4.169 or something like that?
[ ] btt4.168-2386.zip should render borders correctly
