Hi, is there a way to get a floating submenu to close when clicking outside of it and to get the main menu to show when you next open the option instead of still being on the submenu?
good point, I'll add a way to achieve that. It should already be possible with the "on disappear" trigger, but there seems to be an issue with that right now. I'll fix that.
Thanks! U never cease to amaze me with how fast and well u do things!
Hey Andreas this works even on Version: 5.273 (2025031801). Is the issue ericlantz0 is reporting for a newer version or it doesn't work only in some cases?
before the current version it sometimes worked but sometimes failed (on my system it almost always failed) - a very subtle timing issue
