Floating Menu not appearing centered anymore
BetterTouchTool Version: 6.304
System: Mac Studio M4 Max
OS Version: 26.3.1 (a)
My issue: I am on the regular release channel of BTT. Since this (and the previous) update, my floating menus do no longer appear as configured and how they worked flawlessly past year. I have assigned the floating menus to a trigger that opens them centered by the mouse position. This does still work in the most recent version but only once. If I close the floating menu and restart it through my trigger, it now appears on the top left corner relative to the current mouse position, so no longer centered. If I restart BTT, it will work centered again but only once. Each following trigger of the same menu will shift the menu anchor from center to top left again until the next restart of BTT.
It would be great if that could be addressed because I love my floating BTT menus. :grin:
Thank you!
weird it still seems to work fine here, is you menu position configured like this?
Are you using a fixed size for the menu or the "fit content" option? (maybe the fit content calculation fails causing the menu jump)
In case you are using the "fit content" option, 6.305 should improve the behavior
Yes, it looks exactly like your screenshot and I do use the “fit content” option indeed.
I updated to BTT 6.306 and it seems to help with the issue. If I do not spam the menu open/close and just use it like a normal human being, it does the trick. However if I open and close it rapidly (under one minute of wait basically), the forementioned bug re-appears and once it’s there, it does not seem to go away until BTT is restarted. I personally can live with this tiny flaw and I’m glad you could help me. Thank you!
